Похоже вы запускаете AOS на чистой (новой) базе, а в ней нет процедур createserversessions и createusersessions.
X++: CREATE procedure [dbo].[createusersessions] @clientType int, @sessionType int, @serverid int, @versionid int, @loginTime int, @userid varchar(5), @lanExt varchar(10), @manExt varchar(10), @dataFile varchar(3), @sid varchar(124), @recid bigint, @startId int, @maxusers int, @licenseType int, @sessionid int OUTPUT as declare @return_val as int declare @first as int declare @max_val as int begin select @sessionid = -1 if(not exists(select * from SysServerSessions WITH (NOLOCK) where SERVERID = @serverid AND Status = 1)) begin select @sessionid = -2 return end select top 1 @first=SESSIONID from SysClientSessions WITH (UPDLOCK,READPAST) where STATUS = 0 if (select count(*) from SysClientSessions where SESSIONID IN (@first)) > 0 begin if (@licenseType = 0) begin update SysClientSessions set STATUS = 1, VERSION = @versionid, SERVERID = @serverid, USERID = @userid, LOGIN_DATE = GETUTCDATE(), LOGIN_TIME = @loginTime, SID = @sid, USERLANGUAGE = @lanExt, HELPLANGUAGE = @manExt, COMPANY = @dataFile, CLIENTTYPE = @clientType, SESSIONTYPE = @sessionType where SESSIONID IN (@first) end else if (@licenseType = 1) begin update SysClientSessions set STATUS = 1, VERSION = @versionid, SERVERID = @serverid, USERID = @userid, LOGIN_DATE = GETUTCDATE(), LOGIN_TIME = @loginTime, SID = @sid, USERLANGUAGE = @lanExt, HELPLANGUAGE = @manExt, COMPANY = @dataFile, CLIENTTYPE = @clientType, SESSIONTYPE = @sessionType where SESSIONID IN (@first) and ((select count(SESSIONID) from SysClientSessions where CLIENTTYPE = @clientType and ((STATUS = 1) or (STATUS = 2))) < @maxusers) end else if (@licenseType = 2) begin update SysClientSessions set STATUS = 1, VERSION = @versionid, SERVERID = @serverid, USERID = @userid, LOGIN_DATE = GETUTCDATE(), LOGIN_TIME = @loginTime, SID = @sid, USERLANGUAGE = @lanExt, HELPLANGUAGE = @manExt, COMPANY = @dataFile, CLIENTTYPE = @clientType, SESSIONTYPE = @sessionType where SESSIONID IN (@first) and ( (select count(SESSIONID) from SysClientSessions where CLIENTTYPE = @clientType and (USERID = @userid) and ((STATUS = 1) or (STATUS = 2))) > 0 or (select count(distinct USERID) from SysClientSessions where CLIENTTYPE = @clientType and ((STATUS = 1) or (STATUS = 2))) < @maxusers ) end if @@ROWCOUNT = 0 select @sessionid = 0 else select @sessionid = @first end else begin if (@licenseType = 1) begin if (select count(SESSIONID) from SysClientSessions where CLIENTTYPE = @clientType and ((STATUS = 1) or (STATUS = 2))) >= @maxusers select @sessionid = 0 end else if (@licenseType = 2) begin if ( ((select count(distinct USERID) from SysClientSessions where CLIENTTYPE = @clientType and ((STATUS = 1) or (STATUS = 2))) >= @maxusers) and ((select count(SESSIONID) from SysClientSessions where CLIENTTYPE = @clientType and (USERID = @userid) and ((STATUS = 1) or (STATUS = 2))) = 0) ) select @sessionid = 0 end if (@sessionid = -1) or (@licenseType = 0) begin if (select count(SESSIONID) from SysClientSessions WITH (UPDLOCK)) = 0 select @max_val = @startId else select @max_val= max(SESSIONID)+1 from SysClientSessions WITH (UPDLOCK) insert into SysClientSessions(SESSIONID, SERVERID, VERSION, LOGIN_DATE, LOGIN_TIME, USERID, SID, USERLANGUAGE, HELPLANGUAGE, COMPANY, CLIENTTYPE, SESSIONTYPE, RECID, STATUS) values(@max_val, @serverid, @versionid, GETUTCDATE(), @loginTime, @userid, @sid, @lanExt, @manExt, @dataFile, @clientType, @sessionType, @recid, 1) select @sessionid = @max_val CREATE procedure [dbo].[createserversessions] @aosId varchar(50), @version int, @instanceName nvarchar(50), @loginTime int, @recid bigint, @maxservers int, @status int, @loadbalance int, @workload int, @serverid int OUTPUT as declare @first as varchar(50) declare @max_val as int begin select top 1 @first=SERVERID from SysServerSessions WITH (UPDLOCK, READPAST) where AOSID = '' if (select count(SERVERID) from SysServerSessions where SERVERID IN (@first)) > 0 begin update SysServerSessions set AOSID=@aosId, VERSION=@version, INSTANCE_NAME=@instanceName, LOGIN_DATE = GETUTCDATE(), LOGIN_TIME = @loginTime, LASTUPDATETIME = @loginTime, STATUS = @status, LOADBALANCE = @loadbalance, WORKLOAD = @workload where SERVERID IN (@first) and ((select count(SERVERID) from SysServerSessions where AOSID <> '') < @maxservers) if @@ROWCOUNT = 0 select @serverid = 0 else select @serverid = @first end else begin if (select count(SERVERID) from SysServerSessions WITH (UPDLOCK) where AOSID <> '') >= @maxservers select @serverid = 0 else begin if (select count(SERVERID) from SysServerSessions) = 0 select @max_val = 1 else select @max_val = max(SERVERID)+1 from SysServerSessions insert into SysServerSessions(SERVERID, AOSID, INSTANCE_NAME, VERSION, LOGIN_DATE, LOGIN_TIME, LASTUPDATETIME, STATUS, RECID, LOADBALANCE, WORKLOAD) values(@max_val, @aosId, @instanceName, @version, GETUTCDATE(), @loginTime, @loginTime, @status, @recid, @loadbalance, @workload) select @serverid = @max_val |
