Dianne Siebold: Update on the Dynamics AX SDK Team
Источник: http://blogs.msdn.com/dsiebold/archi...dk-update.aspx
============== The Dynamics AX SDK team is responsible for the product developer documentation. Lately, I have been getting the word out about what the SDK team has been doing lately and catch up anyone who's interested on what’s new with the developer documentation. We have been up to a lot since the 4.0 release. The full update follows below in this post and is also attached as a Word doc. Microsoft Dynamics AX Developer Documentation Update September 2007 The SDK Team 2.0 The writers for the Microsoft Dynamics AX SDK are located in the three locations where the development work is done: Fargo and Redmond in the US and Vedb?k in Denmark. In March 2007, we welcomed four new SDK writers to the team from another project, and in July, two writers from the Dynamics GP team also joined the SDK team. These additional writers have enabled the SDK team to take on additional projects and add more 4.0 content as well as start work on documenting the 5.0 release. New Content Since the 4.0 release, the SDK team has been hard at work adding over 5,500 new topics to the online Help. These topics include information about: · Class and table reference – Several thousand new topics have been released describing some of the most commonly used class and table methods. We’ve also added some basic information about syntax and the run on value to other method topics. · Creating forms – New topics contain updated information about how to create and customize forms using the AOT and by using X++ code. · Developer tools – Topics describe new tools such as the unit test framework, the version control system and the reverse engineering tool. The documentation for other tools has been updated and improved. · Development best practices – The new best practices checks for 4.0 are described, and the documentation for the existing checks has been extended and revised. · Code Access Permission framework – This documentation describes how to use classes protected by code access security, lists the classes that are protected and describes how to protect your own APIs. · Database – New topics contain updated information on the database objects in Microsoft Dynamics AX 4.0 including tables, maps, views, queries, and indexes. Documentation about optimistic concurrency control has also been updated. · Application Integration Framework (AIF) – The AIF developer documentation for 4.0 is now complete. It contains updated information on the AIF framework as well as walkthrough documentation on creating a custom general ledger document class. AX Developer Center Microsoft Dynamics AX developers now have a centralized resource on MSDN—the Dynamics AX Developer Center. This resource provides developers with a single location to learn more about developing in AX. The Dynamics AX Developer Center can be found at: http://msdn2.microsoft.com/en-us/dynamics/ax/default.aspx Here’s a quick guide to what you’ll find:
The SDK team follows a continuous publishing model which means that each month SDK content is added and updated on MSDN. This content can be found at: http://msdn2.microsoft.com/en-us/library/aa493472.aspx. To download a list of what’s new in the latest SDK content on MSDN, go to http://www.microsoft.com/downloads/details.aspx?familyid=23fa33f1-1879-4982-8c16-583d89c40901&displaylang=en. If you search for help in the .chm help files that ship with Microsoft Dynamics AX and don’t find what you’re looking for, be sure to check online at MSDN. New HelpKit Did you know that the Help files that ship with Microsoft Dynamics AX are extensible? If you want to add to the current Help content or if you have custom screens or modules that you would like to document in the Help, you can do so. To get a jump-start on customizing the Help files, we have created a “HelpKit.” The HelpKit enables partners and customers to create their own .chm files and link them directly into the AX documentation system. Download the HelpKit from MSDN at: https://mbs.microsoft.com/nr/rdonlyres/a9cba030-ff0a-45b0-9c26-a37b78ca8438/9350/helpkit.zip. More White Papers New white papers that cover setting up AIF and version control are available.
· Version Control System Setup – Guides you through the process of setting up and configuring version control using Visual Studio 2005 SourceSafe (VSS). This paper is available on PartnerSource and CustomerSource (you’ll need a valid login to either of these sites access these white papers). New Book for Developers In the fall of 2006, Microsoft Press released a book for Microsoft Dynamics AX developers entitled Inside Microsoft Dynamics AX 4.0. With this book, you’ll learn how to use the development tools, work with the X++ programming language, as well as customize tables, class forms, and reports. This book also covers advanced development topics including the reflection APIs and performance. Future SDK Plans The SDK team is hard at work creating new documentation to help you navigate the Microsoft Dynamics AX development environment. We are currently working on documentation for the 5.0 release. Some of the things we’re looking at adding to the content for the next release include:
| Теги |
| что нового, ax2009 |
