#5 |
Request No. 10500
KB 909285 Short Desc AOS allows connections on low resources Problem The AOS accepts connection requests from new clients when it is already under a load that is causing user performance to slow or crash. Solution Registry Keys that tighten configuration when the AOS is in a low resource scenario have been added. If these limits are reached, the AOS will reject new connections. If these keys do not exist or exist without a value, Axapta uses the default value listed for each key. If enabling these keys, configure them for each instance of the AOS that is running. \HKLM\SYSTEM\CurrentControlSet\Services\Axapta Object Server\Applications\<AOS Instance Name>\3.0\<AOS Config Name> The following table lists the default values, which are also the recommended values. Note that they are also string values. Код: Regkey Type Min Max Default MaxConcurrentSessions REG_SZ1 100 65535 100 MaxMemPercentage REG_SZ1 50 100 50 MaxMemPercentage Set this value to the percentage of memory that you want the AOS process (ax32serv.exe) to use. This total memory percentage, includes pagefile. Последний раз редактировалось gl00mie; 17.07.2007 в 22:23. |
| За это сообщение автора поблагодарили: George Nordic (3), Logger (3), dmitrybarynov (1). | |
| Теги |
| ax3.0 |
