Старый 14.03.2007, 22:00   #3
25,751 / 851 (80) +++++++
dynamicsmatters: Upgrading from V3 to V4 P3
Источник: http://dynamicsmatters.blogspot.com/...-to-v4-p3.html
Well here we go I carry on my run through of some of the obstacles I have faced in upgrading from V3 to V4.
The CreateLine function on the SalesLine Table has an added parameter that controls credit checking behaviour, incosiderately MS have choosen to add the new parameter before the last parameter which is a string. This means that even though it is defaulted if you are using that last parameter your code fails because of type checking.
They should really think before acting !
Hopefully for the future they will not in version 4.1 4.5 5.0 repeat some of these rather cavalier changes all over the place.
What's with the changing of all the tab page elements in all forms to be named Tab, do they not realise what pain they cause for any changed forms, you cannot just migrate you practically have to hand code / port the changes.
And making what I would call gratuitous changes to the names of Tabs inside a form is just silly, why do you need to rename a Tab from NotificationToCentralBank to NotificationToTheCentralBank example taken from the CustTable form.
Anyhow making long names in Ax is sometimes counterproductive as only a certain number of charachters are used to distinguish elements so it can actually be dangerous unless V4 is improved in this area.
But in any case such changes are silly and add nothing to the value of the product.
To be continued
/Sven
msdynamicsax: Upgrading a database from Ax 4.0 SP1 to Ax 2009 Blog bot DAX Blogs 1 13.08.2008 14:02
dynamicsmatters: Refreshing screen info in V4 Blog bot DAX Blogs 0 16.07.2007 02:58
dynamicsmatters: V3 - V4 Interesting bug Blog bot DAX Blogs 0 16.07.2007 02:58
dynamicsmatters: Upgrading from V3 to V4 Part IV Blog bot DAX Blogs 0 16.04.2007 17:50
dynamicsmatters: New Fix distribution policy Horror from MS Blog bot DAX Blogs 0 16.04.2007 17:50
Часовой пояс GMT +3, время: 20:35.
