Старый 25.01.2007, 15:47   #2
MironovI is offline
MironovI
724 / 77 (4) ++++
If SharePoint Services is installed on the same machine as your reporting server, you must add the /reports and /reportserver paths to the list of excluded paths in SharePoint Services. If you do not add these paths to the list of excluded paths in SharePoint, Axapta will not be able to locate the Reporting Services URLs and therefore you will not be able to link Microsoft Dynamics AX and Reporting Services.
From the Start menu, click Administrative Tools > SharePoint Central Administration.
Click Configure Virtual Server Settings.
Click Default Web Site.
Click Define Managed Paths.
Under Add a New Path, enter /reports in the Path text box.
Select the Excluded Path option.
Click OK.
Enter /reportserver in the Path text box.
Click OK.
ax4.0
Dynamics AX: WCF: The Enterprise Service Bus for Dynamics AX and the rest of the Microsoft Stack Blog bot DAX Blogs 0 10.03.2009 16:05
Dynamics AX: Microsoft's strategy and vision for Dynamics AX and SOA Blog bot DAX Blogs 0 05.03.2009 18:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Service Pack 1 Released Blog bot DAX Blogs 5 21.11.2008 17:00
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 04:42.
