Примеры к книге
Примеры к книге доступны по ссылке: http://www.microsoft.com/mspress/com...0-7356-2257-4/
Примеры даны для следующих глав (наименования глав взяты отсюда, т.е. без нарушения копирайта ):Код: Part I - A Tour of the Development Environment
4 - MorphX Development Tools
Part II - Developing with Axapta
6 - Customizing Dynamics Ax
7 - Extending Dynamics Ax
8 - Developing Applications Using Business Connector
Part III - Under the Hood ("под капотом")
12 - The Database layer
13 - Advanced MorphX Forms
14 - Reflection
15 - System Classes
16 - Unit testing
17 - PerformanceКод: \Chapter04 \Chapter06 \Chapter07 \Chapter08 \Chapter12 \Chapter13 \Chapter14 \Chapter15 \Chapter16 \Chapter17 \Readme.txt \Chapter04\Class_SysBPCheckMemberFunction.xpo \Chapter06\Project_FormImageJoinedDataSources.xpo \Chapter06\Project_FormImageTabActivated.xpo \Chapter06\Project_InventoryDimensions.xpo \Chapter06\Project_NumberSequence.xpo \Chapter06\Project_ReportImageNoEmptyBodySection.xpo \Chapter06\Project_ReportImageOptimized.xpo \Chapter07\PrivateProject_BikeTuningOffers_Basic.xpo \Chapter07\PrivateProject_BikeTuningOffers_Constructors.xpo \Chapter07\PrivateProject_BikeTuningOffers_PropertyMethods.xpo \Chapter07\PrivateProject_BikeTuningOffers_Query.xpo \Chapter07\PrivateProject_InventItemCreateWizard.xpo \Chapter08\AccessingDataBC.cs \Chapter08\HelloWorldBC.cs \Chapter08\InvokingBusinessLogicBC.cs \Chapter08\PrivateProject_InsideDynamicsAXChapter8.xpo \Chapter12\Job_RecVersionChange.xpo \Chapter12\Job_skipTTSCheck.xpo \Chapter12\Job_TmpCustTable.xpo \Chapter12\Job_TmpLedgerTable with freed dataset.xpo \Chapter12\Job_TmpLedgerTable with index violation.xpo \Chapter12\Job_TmpLedgerTable without index violation.xpo \Chapter12\Job_TmpLedgerTableAbort using record buffer ttsabort.xpo \Chapter12\Job_TmpLedgerTableAbort using ttsabort.xpo \Chapter12\Job_UpdateCreditRating using optimistic concurrency.xpo \Chapter12\Job_UpdateCreditRating using pessimistic concurrency.xpo \Chapter12\Job_UpdateCustomers with isolation levels.xpo \Chapter12\Job_UpdateCustomers with transaction level.xpo \Chapter12\Job_UpdateVendors enforcing uncommitted read.xpo \Chapter12\Job_UpdateVendors using per record commit.xpo \Chapter13\PrivateProject_AdvancedMorphXForms.xpo \Chapter14\PrivateProject_Reflection.xpo \Chapter15\PrivateProject_SystemClasses.xpo \Chapter16\Class_StackTest.xpo \Chapter17\Class_CopySizes using RecordSortedList.xpo \Chapter17\Class_FiniteLoop.xpo \Chapter17\Class_InfiniteLoop.xpo \Chapter17\Class_RecordViewCacheUse.xpo \Chapter17\Job_AgingScheme.xpo \Chapter17\Job_BalanceMST using exists join.xpo \Chapter17\Job_BalanceMST using tableId.xpo \Chapter17\Job_BalanceMST with complete field list.xpo \Chapter17\Job_BalanceMST with limited field list.xpo \Chapter17\Job_CopySizes using record based insert.xpo \Chapter17\Job_CopySizes using RecordInsertList.xpo \Chapter17\Job_CopySizes using set based insert.xpo \Chapter17\Job_CopySizes using skipDataMethods.xpo \Chapter17\Job_DeleteSizes using record based deletes.xpo \Chapter17\Job_DeleteSizes using set based delete.xpo \Chapter17\Job_expandingFieldList.xpo \Chapter17\Job_NotInTTSCache.xpo \Chapter17\Job_ReuseRecordBuffer.xpo \Chapter17\Job_UpdateCreditMax leveraging optimistic concurrency.xpo \Chapter17\Job_UpdateCreditMax using record based commit.xpo \Chapter17\Job_UpdateCreditMax using set based commit.xpo \Chapter17\Job_UpdateCreditMax with full field list.xpo \Chapter17\Job_UpdateCustomers using record based update.xpo \Chapter17\Job_UpdateCustomers using set based update.xpo \Chapter17\Job_UpdateSizes using record based updates.xpo \Chapter17\Job_UpdateSizes using set based update.xpo \Chapter17\Job_UtilizeCache.xpo \Chapter17\PrivateProject_ServerClass with bundled call.xpo \Chapter17\PrivateProject_ServerClass with single calls.xpo \Chapter17\PrivateProject_ServerClass with static method.xpo |
| Теги |
| download, документация, ax4.0 |
