Старый 15.08.2006, 14:23   #5
RVS is offline
RVS
Сенбернар
Аватар для RVS
696 / 130 (6) +++++
Источник : Axapta - Руководство разработчика. Поиск по слову lookup
Creating a run-time lookup form
A standard lookup form is created through relations on the database table, and on the Extended Data Type. To learn about the standard lookup form, click ...
If, however, you need to create a runtime lookup form that looks up other database fields than the ones offered by the standard lookup form, use the application class SysTableLookup and override the lookup method on the relevant form control.
How to use the SysTableLookup class
Create a new instance of SysTableLookup where 'this' is the current form control
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tableNum(custTable), this);
Add the fields to be shown in the lookup form
sysTableLookup.addLookupField(fieldNum(custTable, accountNum));
Limit the data selection.
queryBuildDataSource = query.addDataSource(tableNum(custTable));
queryBuildRange = queryBuildDataSource.addRange(fieldNum(custTable, accountNum));
queryBuildRange.value('A..B');
sysTableLookup.parmQuery(query);
Perform the lookup, and delete super().
super() will create an autogenerated lookup form.
sysTableLookup.performFormLookup();
// super()
A complete example of overriding the lookup method on a form control
void lookup()
Query query = new Query();
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange queryBuildRange;
// Create an instance of SysTableLookup where 'this' the current Form control.
// The field to be shown in the lookup form.
sysTableLookup.addLookupField(fieldNum(custTable, name));
// Limit and arrange data selection.
// Perform lookup
// do not call super().
// super()
void lookup()
SysTableLookup sysTableLookup;
TableId tableId;
FieldId fieldId;
tableId = tablename2id('myTable');
sysTableLookup.parmTableId(tableId);
fieldId = fieldname2id(tableId, 'MyField_1');
sysTableLookup.addLookupfield(fieldId);
fieldId = fieldname2id(tableId, 'MyField_2');
queryBuildDataSource = query.addDataSource(tableId);
queryBuildDataSource.orderMode(OrderMode::GROUPBY);
queryBuildDataSource.addSortField(fieldId));
this.performFormLookup(sysTableLookup.formRun());
This manner of creating a lookup form is used in the DocuType form in the application. The full path to the modified lookup method is:
\Forms\DocuType\Designs\Design\[Tab:Tab]\[TabPage:Overview]\[Grid:Grid]\StringEdit:ActionClassName\Methods.
Note
The SysTableLookup is limited to making lookups on fields in a table.
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
Фильтрация в lookup labuzov DAX: Программирование 2 08.07.2004 14:32
Фильтрация в Lookup-форме Rem DAX: Программирование 5 27.04.2002 08:27
Часовой пояс GMT +3, время: 04:45.
