Старый 08.08.2006, 11:30   #22
Jabberwocky is offline
Jabberwocky
Microsoft Dynamics
Аватар для Jabberwocky
274 / 307 (11) ++++++
Пример из Developer's Guide:
Modifying the Fetch method on a report
The Fetch method is the main loop of a report. The programmer may override the fetch method if there are very special constraints on which records to show. The Fetch method can be modeled in X++ as
//Create a new query to fetch the records
QueryRun qr = new QueryRun(element.query());
//Open the prompt dialog
if(qr.prompt())
{ //The user didn't press cancel
while(qr.next())
file = qr.get(file); //For all data sources
send(file);
If you want to print only records that satisfy some special constraint that is difficult to express as a range in the query, write the code above, and only allow Send to be called if the constraint (expressed as a function by the same name in the example below) is satisfied:
while (qr.next())
if(constraint())
send(file);
You should use Bing before asking dumb questions.
Не страшно ли временные таблицы временно сделать постоянными? Gustav DAX: Программирование 11 09.02.2006 11:04
Временные таблицы должны быть вложенными (inner)... Deep Dreamer DAX: Программирование 14 08.09.2005 16:23
Временные таблицы в отчетах konfet DAX: Программирование 5 19.01.2005 11:32
Временные таблицы vasiliy DAX: Программирование 6 09.11.2004 11:04
Временные таблицы Diamond DAX: Программирование 3 30.12.2003 09:33
Часовой пояс GMT +3, время: 05:55.
