Go Back   AXForum > Microsoft Dynamics AX > DAX: Программирование
Forgotten Your Password?
Register Forum Rules FAQ Members List Today's Posts Search
Thread Tools Search this Thread Display Modes
Old 11.04.2006, 07:12   #1
Sada is offline
Sada
Программатор
Sada's Avatar
1,450 / 153 (8) ++++++
Не могу понять в чем ошибка???
Доброго всем времени суток, уважаемые коллеги.
есть вот такой кусок кода:
PHP Code:
   Query                                 q = new Query();
QueryBuildDataSource        ds,ds2,ds3;
queryRun                            qr;
ds q.addDataSource(tablenum(InventTrans));
ds.addSelectionField(fieldnum(InventTrans,TransType));
ds.addSelectionField(fieldnum(InventTrans,StatusIssue));
ds.addSelectionField(fieldnum(InventTrans,DateStatus));
ds.addSelectionField(fieldnum(InventTrans,ItemId));
ds.addSelectionField(fieldnum(InventTrans,InventTransId));
ds.addSelectionField(fieldnum(InventTrans,Qty));
ds.addSelectionField(fieldnum(InventTrans,CustVendAC));
s"((inventTrans.StatusIssue == statusIssue::Sold || inventTrans.StatusReceipt == statusReceipt::Purchased))";
q.dataSourceTable(TableNum(InventTrans)).addRange(FieldNum(InventTrans,recId)).value(s);
ds.addRange(fieldNum(InventTransDateStatus)).value(sysQuery::range(PlanDateFromPlanDateTo));
ds.addRange(fieldNum(InventTransTransType)).value(QueryValue(InventTransType::Sales));
ds.orderMode(OrderMode::OrderBy);
ds.addSortField(fieldnum(InventTransItemId));
ds2 ds.addDataSource(tableNum(CustInvoiceTrans));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,InventTransId));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,Scrap));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,SalesPrice));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,Qty));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,LineAmount));
ds2.addSelectionField(fieldnum(CustInvoiceTrans,TaxAmount));
ds2.joinMode(JoinMode::InnerJoin);
ds2.fetchMode(0);
ds2.addLink(fieldNum(InventTrans,InventTransId),fieldNum  (CustInvoiceTrans,InventTransId));
ds3 ds.addDataSource(tablenum(CustTable));
ds3.relations(true);
ds3.joinMode(JoinMode::InnerJoin);
ds3.fetchMode(0);
ds3.addSelectionField(fieldnum(CustTable,Name));
ds3.addSelectionField(fieldnum(CustTable,Agent));
qr = new QueryRun(q);
    while (
qr.next())
обработка данных..
на эту конструкцию мне Аксапта выдает "Ошибка расширенного диапазона запроса: inventTrans.StatusIssue не является корректной парой datasource.field рядом с 30
Подскадите плиз, что бы это значило. ошибка появляется на строке while (qr.next())....
C Уважением - Sada...
Old 11.04.2006, 08:39   #2
TasmanianDevil is offline
TasmanianDevil
Мрачный тип
TasmanianDevil's Avatar
887 / 389 (14) ++++++
Обычный бред Аксапты на очевидную ошибку
Все Range.Value - строки , т.е. надо написать s="Продано,Куплено"
Old 11.04.2006, 08:52   #3
Sada is offline
Sada
Программатор
Sada's Avatar
тоесть нада вот это исправить
s= "((inventTrans.StatusIssue == statusIssue::Sold || inventTrans.StatusReceipt == statusReceipt::Purchased))";
но на ЧТО?(попробовал не получилось...)
Old 11.04.2006, 08:57   #4
TasmanianDevil
Мрачный тип
прошу прощения, не разобрался - Вы в фильтре хотите наложить ограничения на два поля , а не на одно
Скобочки одинарные, OR и просто имена полей не помогают ?
Old 11.04.2006, 09:03   #5
Sada is offline
Sada
Программатор
Sada's Avatar
Quote:
Originally Posted by TasmanianDevil
прошу прощения, не разобрался - Вы в фильтре накладываете ограничения на два поля , а не на одно
В любом случае в значение фильтра по полю имеющему перечислимы тип - есть строка, и пихать туда надо именно строковое значение соответствующего числового значения перечислимого типа
да на два, и мне именно нада чтоб был OR...
Old 11.04.2006, 09:13   #6
Sada is offline
Sada
Программатор
Sada's Avatar
Хелп...
Old 11.04.2006, 09:29   #7
AndyD is offline
AndyD
КОРУС Консалтинг
2,560 / 2499 (89) +++++++++
Во-первых, добавьте имя датасоурса
    ds = q.addDataSource(tablenum(InventTrans), "InventTrans");
Во-вторых, добавьте скобки
s= "((inventTrans.StatusIssue == statusIssue::Sold) || " +
    "(inventTrans.StatusReceipt == statusReceipt::Purchased))";
В-третьих, TransType устанавливайте так
ds.addRange(fieldNum(InventTrans, TransType)).
    value(int2str(InventTransType::Sales));
или так
    value("(InventTrans.TransType == InventTransType::Sales)");
Axapta v.3.0 sp5 kr2
Old 11.04.2006, 09:35   #8
AndyD is offline
AndyD
КОРУС Консалтинг
Пардон, то, что в-третьих можно не делать
Old 11.04.2006, 09:43   #9
Sada is offline
Sada
Программатор
Sada's Avatar
2AndyD
Спасибо огромное, теперь буду знать!!!Все заработало
Similar Threads
Thread Thread Starter Forum Replies Last Post
В чем ошибка???? a-da DAX: Программирование 3 08.04.2007 00:17
Ошибка при запуске 3-tier nicko DAX: Администрирование 3 02.02.2007 13:44
Ошибка при обработке С-Ф Sergo DAX: Программирование 7 20.01.2006 11:56
Ошибка при закрытии склада, при закрытии более ранней датой, чем пересчет Berkoff DAX: Функционал 2 25.10.2004 17:52
Ошибка при сохранении поставщика Filip DAX: Функционал 19 24.02.2004 08:32
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2025, Jelsoft Enterprises Ltd.
Contacts E-mail, Advertising.
