Старый 04.04.2006, 14:57   #11
Roman777 is offline
Roman777
NavAx
Аватар для Roman777
NavAx Club
320 / 64 (3) ++++
Я все-таки настаиваю на обязательности связки InventSerial.itemId = InventSum.itemId по той причине, что в таблице InventSerial уникальность поддерживается совокупностью полей ItemId и inventSerialId, и предлагаю свой вариант решения:
PHP код:
    Query                   query;
QueryRun                qr;
QueryBuildDataSource    qbdsSum;
QueryBuildDataSource    qbdsDim;
QueryBuildDataSource    qbdsSerial;
QueryBuildRange         qbrItemSerial;
query       =   new Query();
qbdsSum     =   query.addDataSource(tableNum(InventSum));
qbdsSum.orderMode(OrderMode::GroupBy);
qbdsSum.addSortField(fieldnum(InventSumitemId));
qbdsSum.addSelectionField(fieldnum(InventSumitemId));
qbdsSum.addSelectionField(fieldnum(InventSumPostedQty), Selectionfield::Sum);
qbdsSum.addSelectionField(fieldnum(InventSumPostedValue), Selectionfield::Sum);
qbdsDim     =   qbdsSum.addDataSource(tableNum(InventDim));
qbdsDim.orderMode(OrderMode::GroupBy);
qbdsDim.addSortField(fieldnum(InventDiminventDimId));
qbdsDim.addSortField(fieldnum(InventDiminventSerialId));
qbdsDim.addSelectionField(fieldnum(InventDiminventDimId));
qbdsDim.addSelectionField(fieldnum(InventDiminventSerialId));
qbdsDim.joinMode(JoinMode::InnerJoin);
qbdsDim.fetchMode(0);
qbdsDim.addLink(fieldNum(InventSuminventDimId), fieldNum(InventDiminventDimId));
qbdsDim.addRange(fieldNum(InventDiminventSerialId)).value(SysQuery::valueNotEmptyString());
qbdsSerial  =   qbdsDim.addDataSource(tableNum(InventSerial));
qbdsSerial.orderMode(OrderMode::GroupBy);
qbdsSerial.addSortField(fieldNum(InventSerialProdDate));
qbdsSerial.addSelectionField(fieldNum(InventSerialProdDate));
qbdsSerial.joinMode(JoinMode::InnerJoin);
qbdsSerial.fetchMode(0);
qbdsSerial.addLink(fieldNum(InventDimInventSerialId), fieldNum(InventSerialInventSerialId));
qbrItemSerial qbdsSerial.addRange(fieldNum(InventSerialitemId));
qbrItemSerial.value(strfmt("(%1) = %2.%3"fieldstr(InventSerialitemId), qbdsSum.name(), fieldstr(InventSumitemId)));
qr = new QueryRun(query);
    while (
qr.next())
// тут обработка результатов запроса...
Примечание: Так как я меня в таблице InventSerial не оказалось поля AdvertAction, я заменил его на ProdDate, но сути это не меняет.
А вот что выдал трассировщик SQL по этому вопросу:
Код:
SELECT SUM(A.POSTEDQTY),SUM(A.POSTEDVALUE),A.ITEMID,B.INVENTDIMID,B.INVENTSERIALID,C.PRODDATE FROM INVENTSUM A,INVENTDIM B,INVENTSERIAL C WHERE (A.DATAAREAID='zkr') AND ((B.DATAAREAID='zkr') AND ( NOT ((B.INVENTSERIALID=' ')) AND (A.INVENTDIMID=B.INVENTDIMID))) AND ((C.DATAAREAID='zkr') AND ((C.ITEMID=A.ITEMID) AND (B.INVENTSERIALID=C.INVENTSERIALID))) GROUP BY A.ITEMID,B.INVENTDIMID,B.INVENTSERIALID,C.PRODDATE ORDER BY A.ITEMID,B.INVENTDIMID,B.INVENTSERIALID,C.PRODDATE OPTION(FAST 16)
Как собрать запрос? moid DAX: Программирование 11 02.07.2007 12:07
Почему join запрос разбивается на подзапросы!? 3oppo DAX: Программирование 59 28.06.2007 11:52
Не работает запрос на нескольких компаниях Bega DAX: Программирование 3 16.09.2005 10:21
Подскажите пожалуйста, как реализовать запрос через QueryBuild vesna DAX: Программирование 3 24.02.2005 06:52
Можно ли в аксапте реализовать такой SQL запрос: Sergey_1972 DAX: Программирование 14 18.03.2004 16:33
Часовой пояс GMT +3, время: 17:03.
