на ВМ где все работает как надо, запись в MCRSalesTable создается когда пользователь нажимает кнопку Submit (это MCRSalesOrderRecap.SubmitOrder()). Call stack с ВМ где запись создается - на скриншоте внизу.
MCRSalesTable.Insert() делается на Salestable.update(): X++: public class SysExtensionSerializerMap extends common { /* .................... */ /// <summary> /// Updates / inserts the packed extension table record after the base table record is updated. /// </summary> /// <remarks> /// This method should be called immediately after super() of base table's <C>update</C> method. /// </remarks> public void postUpdate() { SysExtensionSerializerExtensionMap currentExtensionTable; SysExtensionSerializerExtensionMap extensionTableToUpdate; SysExtensionSerializerExtensionMap extensionTableInUse; int i; boolean checkForLinkedExtensionTables; container newPackedExtensions; boolean updated; Array extensionTableArray = new Array(Types::Record); container extensionTableTableIdList; TableId currentExtensionTableTableId; container hasLinkedExtensionTableCon; boolean hasLinkedExtensionTable; if (this.RecId && this.PackedExtensions != conNull()) { for (i = 1; i <= conLen(this.PackedExtensions); i++) { currentExtensionTable = con2Buf(conPeek(this.PackedExtensions, i)); extensionTableArray.value(i, currentExtensionTable); currentExtensionTableTableId = currentExtensionTable.TableId; // if buffer is not form DS there is no need to check for extension table on client checkForLinkedExtensionTables = checkForLinkedExtensionTables || FormDataUtil::isFormDataSource(this); extensionTableTableIdList += [currentExtensionTableTableId]; } if (checkForLinkedExtensionTables) { hasLinkedExtensionTableCon = SysExtensionSerializerFormRunHelper::hasExtensionTable(this, extensionTableTableIdList); } ttsbegin; for (i = 1; i <= extensionTableArray.lastIndex(); i++) { updated = false; currentExtensionTable = extensionTableArray.value(i); /* ............................ */ // If it is not an existed record, insert it. if (updated == false) { currentExtensionTable.BaseRecId = this.RecId; currentExtensionTable.insert(); //<<----------------------------- } newPackedExtensions += [buf2Con(currentExtensionTable, true)]; } ttscommit; this.PackedExtensions = newPackedExtensions; } } |
Проблема же не в добавлении записи, а в том что PackedExtensions пустой. Заполняется это поле имхо не на update.
насколько я вижу, заполняется поле тут (в дебаггере вижу что таки заполняется):
X++: class MCRPaymentReview { /*...................................*/ public static boolean outOfBalance(MCRCustPaymTotals _mcrCustPaymTotals, AmountCur _overUnderPaymAmount = 0, AmountCur _totalSalesAmount = 0) { /*.....................................*/ else { // Update back status gets called from so many places that a new // enum value was added so that only end order can put a // sales order on out of balance "hold". // So once end order validates that this is not out of balance // make sure that it doesn't happen again unless the order // is modified. mcrSalesTable.OutOfBalanceReleased = MCROutOfBalanceReleaseType::Verified; } ttsBegin; if (salesTable.validateWrite()) { salesTable.mcrPackMCRSalesTable(mcrSalesTable); //<<---------------------------- salesTable.update(); } else { throw error("@SYS104318"); } ttsCommit; return isValid; X++: public class SalesTable extends common { /*....................................*/ /// <summary> /// Packs the retail sales table extension table into <c>MCRSalesTable</c> field. /// </summary> /// <param name="_mcrSalesTable"> /// Extension table to be packed. /// </param> public void mcrPackMCRSalesTable(MCRSalesTable _mcrSalesTable) { _mcrSalesTable.SalesTable = this.RecId; this.SysExtensionSerializerMap::packExtensionTable(_mcrSalesTable); } |
Теги |
mcrsalestable, packedextensions, sysextensionserializermap |
