Старый 16.11.2016, 00:11   #1
organicax: Installing the modern reports pack
Источник: https://organicax.com/2016/11/15/ins...-reports-pack/
In a previous post we had a look at an example of the modern design reports. You can install them from Lifecycle Service. To evaluate them further you might want to install them into a demo or development environment to review and possible modify them further.
It should be noted that this required Update 3 which is what I’m using in the video.
Here is a quick overview.
D365FO 1611 – Update3 (7.0.4307.16141)
You should note that in the video I do a manual deploy of the SSRS reports because I’m using a one box installation in this case. In a multi-box or regular deployment process these will be updated.
Cheers
Lachlan
Filed under: Business intelligence, Development
organicax: Document branding – modern report designs Blog bot DAX Blogs 0 15.11.2016 11:11
organicax: WMS Mobile Device – pick and pack parameter Blog bot DAX Blogs 0 11.08.2016 06:14
organicax: Purchasing spend analysis reports – data source Blog bot DAX Blogs 0 25.04.2016 21:11
Часовой пояс GMT +3, время: 06:29.
