Сюда запощу код на всякий случай, а то говорят с той ссылкой что-то не так
X++: using System; using System.IO; using System.Drawing.Printing; using System.Runtime.InteropServices; using System.Windows.Forms; namespace Printer { public class RawPrinterHelper { [StructLayout(LayoutKind.Sequential, CharSet = CharSet.Unicode)] public struct DOCINFOW { [MarshalAs(UnmanagedType.LPWStr)] public string pDocName; [MarshalAs(UnmanagedType.LPWStr)] public string pOutputFile; [MarshalAs(UnmanagedType.LPWStr)] public string pDataType; } [DllImport("winspool.Drv", EntryPoint = "OpenPrinterW", CallingConvention = CallingConvention.StdCall, CharSet = CharSet.Unicode, SetLastError = true, ExactSpelling = true)] public static extern bool OpenPrinter(string src, ref IntPtr hPrinter, int pd); [DllImport("winspool.Drv", CallingConvention = CallingConvention.StdCall, CharSet = CharSet.Unicode, SetLastError = true, ExactSpelling = true)] public static extern bool ClosePrinter(IntPtr hPrinter); [DllImport("winspool.Drv", EntryPoint = "StartDocPrinterW", CallingConvention = CallingConvention.StdCall, CharSet = CharSet.Unicode, SetLastError = true, ExactSpelling = true)] public static extern bool StartDocPrinter(IntPtr hPrinter, int level, ref RawPrinterHelper.DOCINFOW pDI); [DllImport("winspool.Drv", EntryPoint = "EndDocPrinter", SetLastError = true, CharSet = CharSet.Unicode, ExactSpelling = true, CallingConvention = CallingConvention.StdCall)] public static extern bool EndDocPrinter(IntPtr hPrinter); [DllImport("winspool.Drv", EntryPoint = "StartPagePrinter", SetLastError = true, CharSet = CharSet.Unicode, ExactSpelling = true, CallingConvention = CallingConvention.StdCall)] public static extern bool StartPagePrinter(IntPtr hPrinter); [DllImport("winspool.Drv", EntryPoint = "EndPagePrinter", SetLastError = true, CharSet = CharSet.Unicode, ExactSpelling = true, CallingConvention = CallingConvention.StdCall)] public static extern bool EndPagePrinter(IntPtr hPrinter); [DllImport("winspool.Drv", CallingConvention = CallingConvention.StdCall, CharSet = CharSet.Unicode, SetLastError = true, ExactSpelling = true)] public static extern bool WritePrinter(IntPtr hPrinter, IntPtr pBytes, int dwCount, ref int dwWritten); public static bool SendBytesToPrinter(string szPrinterName, IntPtr pBytes, Int32 dwCount) { IntPtr hPrinter = System.IntPtr.Zero; Int32 dwError; DOCINFOW di = new DOCINFOW(); Int32 dwWritten = 0; bool bSuccess; di.pDocName = "My Document"; di.pDataType = "RAW"; bSuccess = false; if (OpenPrinter(szPrinterName, ref hPrinter, (int)0)) { if (StartDocPrinter(hPrinter, 1, ref di)) { if (StartPagePrinter(hPrinter)) { bSuccess = WritePrinter(hPrinter, pBytes, dwCount, ref dwWritten); EndPagePrinter(hPrinter); } EndDocPrinter(hPrinter); } ClosePrinter(hPrinter); } if (bSuccess == false) { dwError = Marshal.GetLastWin32Error(); } return bSuccess; } public static bool SendFileToPrinter(string szPrinterName, string szFileName) { FileStream stream1 = new FileStream(szFileName, FileMode.Open); BinaryReader reader1 = new BinaryReader(stream1); byte[] buffer1 = new byte[((int)stream1.Length) + 1]; buffer1 = reader1.ReadBytes((int)stream1.Length); IntPtr ptr1 = Marshal.AllocCoTaskMem((int)stream1.Length); Marshal.Copy(buffer1, 0, ptr1, (int)stream1.Length); bool flag1 = RawPrinterHelper.SendBytesToPrinter(szPrinterName, ptr1, (int)stream1.Length); Marshal.FreeCoTaskMem(ptr1); return flag1; } public static void SendStringToPrinter(string szPrinterName, string szString) { IntPtr pBytes; Int32 dwCount; dwCount = szString.Length; pBytes = Marshal.StringToCoTaskMemAnsi(szString); MessageBox.Show(pBytes.ToString()); SendBytesToPrinter(szPrinterName, pBytes, dwCount); Marshal.FreeCoTaskMem(pBytes); } } } |
Может кто нибудь уже делал это в аксапте, с использованием только X++ и DllFunction (без использования сторонних библиотек) и может поделится кодом ?
![]() Стоит задача прямой печати в принтер Zebra через usb командами EPL/ZPL... Код C# - работает, но не хотелось бы использовать библиотеки dll которые придется копировать на каждого клиента... |
За это сообщение автора поблагодарили: Logger (1). |
Тема | Ответов | |||
Основной принтер . Ах 2009 | 3 | |||
Infolog при печати отчета | 9 | |||
Активность пиктограммы печати | 2 | |||
Очередь печати документов | 3 | |||
Откуда фактура_RU берет количество для печати | 2 |
