Старый 20.10.2014, 03:18   #1
ax_mct is offline
ax_mct
Banned
2,548 / 1091 (0) ++++++++
Сообщение от Narayana Посмотреть сообщение
...А о том порядке, в котором модули грызут запрос.
…про порядок вызова модулей
IIS Pipeline
http://blogs.msdn.com/b/tmarq/archiv...onditions.aspx
BEGIN_REQUEST
AUTHENTICATE_REQUEST
AUTHORIZE_REQUEST
RESOLVE_REQUEST_CACHE
MAP_REQUEST_HANDLER
ACQUIRE_REQUEST_STATE
PRE_EXECUTE_REQUEST_HANDLER
RELEASE_REQUEST_STATE
UPDATE_REQUEST_CACHE
LOG_REQUEST
END_REQUEST
ASP.NET request-processing stages
http://www.iis.net/learn/application...ation-with-iis
Заметка 1: Integrated mode allows both managed and native modules to register for events in the IIS pipeline.
Заметка 2: Think of ASP.NET in classic mode as a pipeline within a pipeline.
BeginRequest. The request processing starts.
AuthenticateRequest. The request is authenticated. IIS and ASP.NET authentication modules subscribe to this stage to perform authentication.
PostAuthenticateRequest.
AuthorizeRequest. The request is authorized. IIS and ASP.NET authorization modules check whether the authenticated user has access to the resource requested.
PostAuthorizeRequest.
ResolveRequestCache. Cache modules check whether the response to this request exists in the cache, and return it instead of proceeding with the rest of the execution path. Both ASP.NET Output Cache and IIS Output Cache features execute.
PostResolveRequestCache.
MapRequestHandler. This stage is internal in ASP.NET and is used to determine the request handler.
PostMapRequestHandler.
AcquireRequestState. The state necessary for the request execution is retrieved. ASP.NET Session State and Profile modules obtain their data.
PostAcquireRequestState.
PreExecuteRequestHandler. Any tasks before the execution of the handler are performed.
ExecuteRequestHandler. The request handler executes. ASPX pages, ASP pages, CGI programs, and static files are served.
PostExecuteRequestHandler
ReleaseRequestState. The request state changes are saved, and the state is cleaned up here. ASP.NET Session State and Profile modules use this stage for cleanup.
PostReleaseRequestState.
UpdateRequestCache. The response is stored in the cache for future use. The ASP.NET Output Cache and IIS Output Cache modules execute to save the response to their caches.
PostUpdateRequestCache.
LogRequest. This stage logs the results of the request, and is guaranteed to execute even if errors occur.
PostLogRequest.
EndRequest. This stage performs any final request cleanup, and is guaranteed to execute even if errors occur.
ASP.NET Application Life Cycle Overview for IIS 7.0
http://msdn.microsoft.com/en-us/libr...v=vs.100).aspx
Execution order of modules in IIS7
http://www.ksingla.net/2006/06/execu...dules_in_iis7/
Думаю что для вас самое интересное это
If multiple modules subscribe to the same event and set the same priority, the module that is listed first in the system.webServer/modules section gets executed first. RQ_EXECUTE_REQUEST_HANDLER is different in this respect as it picks up the ordering from system.webServer/handlers section. Taking the example of StaticFile handler entry from default IIS configuration which looks like the following
<add name="StaticFile" path="*" verb="*" modules="StaticFileModule,DefaultDocumentModule,DirectoryListingModule" resourceType="Either" requireAccess="Read" />
IIS picks one handler for a request but each entry can have multiple modules executed which can appear as comma separated list as is the case for StaticFile handler. StaticFileModule, DefaultDocumentModule and DirectoryListingModule, all three subscribe to RQ_EXECUTE_HANDLER and use default priority. The default ordering of these modules is important to ensure they work correctly.
Ссылки далеко не все "официальные" но на мой взгляд информация корректна.
Старый 21.10.2014, 14:22   #2
Narayana is offline
Narayana
241 / 100 (4) +++++
Сообщение от ax_mct Посмотреть сообщение
IIS Pipeline
Кажется, немного разобрался.
Когда читаешь, нужно все время понимать, где находишься... в конвейере IIS, конвейере приложения или конвейере страницы.
Пожалуй, именно непонимание этого вызывало у меня бурные эмоции.
Сейчас полегчало
ax2012, enterprise portal, sharepoint
emeadaxsupport: Get started with AX 2012 R3! Blog bot DAX Blogs 0 05.05.2014 09:11
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
Часовой пояс GMT +3, время: 17:21.
