You can export customizations from a server that is running Microsoft Dynamics CRM 4.0 with Update Rollup 2 or a later update rollup. Then, you can import those customizations to a server that has Update Rollup 18 installed. You can also export customizations from a server that is running Microsoft Dynamics CRM 4.0 with Update Rollup 18 installed. Then, you can import those customizations to a server that has Update Rollup 2 or a later update rollup installed. If you export customizations from a server that is running Microsoft Dynamics CRM 4.0, you must not import the customizations to the Microsoft Dynamics CRM 4.0 server in the following scenarios:
http://fixrm.wordpress.com, снятие/наведение порчи. Быстро, дорого, гарантия. ![]() ![]() |
Опции просмотра | |
