Старый 06.05.2011, 02:19   #1
axdaily: Collaboration request
Источник: http://axdaily.blogspot.com/2011/05/...n-request.html
I strongly believe that the blog content consists of two equally important parts – author's input (through the posts) and readers' input (through the comments).
And so I decided to try to boost the second part a little bit and I need your help here.
This post will stay on top since now and I am asking you to write in comments to this post anything you will be interested to read about in this blog.
It can be a request to explain some AX 2012 feature, suggestion of the topic\tip\trick that might be interesting to others, bug report, … basically anything. And I will be replying to that with posts.
And I would also like to welcome you to comment\ask questions\start discussions in all other posts as well.
Thanks!
axdaily: SQL temporary tables in AX 2012 Blog bot DAX Blogs 25 06.05.2011 10:18
axdaily: WCF services in AX 2012 Blog bot DAX Blogs 0 30.04.2011 01:13
axdaily: Development environment in AX 2012 Blog bot DAX Blogs 0 23.04.2011 07:11
Microsoft Dynamics CRM Team Blog: ASP.NET 2.0.50727.0 Warning Event ID: 1309 due to Request time out Blog bot Dynamics CRM: Blogs 0 21.11.2008 02:08
The request failed with HTTP status 400: Bad Request ZooY Dynamics CRM: Разработка 3 11.08.2008 08:09
Часовой пояс GMT +3, время: 08:48.
