Это действительно полезно? Если полезно, то что нужно сделать на форуме, чтобы люди находили быстро? добавить теги? добавить на первую страницу? |
Ищущий знания...
![]() я так понимаю можно эти XPO загрузить в аху, и посмотреть примеры программирования на X++.
"Страх перед возможностью ошибки не должен отвращать нас от поисков истины." (с) С Уважением, Елизаров Артем |
================================= WHAT'S IN THIS COMPANION CONTENT? ================================= This companion content contains the code samples presented in the book. These samples are intended for you to use in a demo environment and are not suitable for a production environment. ================================= HOW TO USE THIS COMPANION CONTENT ================================= Applying the Dynamics AX 2009 sample code ----------------------------------------- Before you can start using the sample code presented in chapters 3, 5, 6, 10, 12, 14 and 15 you must be aware of the following: a) Chapter specific guidelines or information to implement the code samples are available in the appropriate .XPO file. b) The Dynamics AX 2009 demo data must be imported into the application. c) The code samples are built using a default installation. This means that only the SYS and USR layers are installed. If other layers (such as GLS, DIS, VAR, etc.) have been installed, the code in any of these layers may not work as expected. d) The sample code may not work in combination with other code samples from the book. e) The samples are provided for testing purposes only; no support is available for the sample code. f) The following information applies to chapter 6: Filenames of the code samples match the book chapters as follows: Chapter Filename Wizards PrivateProject_InventItemCreateWizard Creating the class PrivateProject_BikeTuningOffers_Basic Adding Property Methods PrivateProject_BikeTuningOffers_PropertyMethods Adding Constructors PrivateProject_BikeTuningOffers_Constructors Adding a Query PrivateProject_BikeTuningOffers_Query Labels are included in the XPO files and will be added to your default label file. To run the Bike-Tuning Service Offers examples you must have access to an SMTP server, and the details about the server must be entered in Dynamics AX under Administration\Setup\E-mail parameters. Should the e-mail features in the example not be required they can be removed or the lines commented out using the SysMailer class from the sendOffers method in the BikeTuningOffers class. g) The following information applies to chapter 10: To run each of the chapter 10 code samples, follow these steps: 1. Verify that the .NET Business Connector is installed using Add/Remove Programs in the Control Panel. (It is not installed by default with the Dynamics AX client.) Note: the Business Connector is not listed separately in Add/Remove programs, so you must invoke Microsoft Dynamics AX Setup, select Add or modify components, and then see whether .NET Business Connector is grayed out. If it is grayed out, that means it is installed. 2. Verify that you can successfully log on to Dynamics AX using the AX client. 3. In the AX client, select Tools\Options. Make sure that Start company accounts is set to a company that has data in the InventTable table. 4. Create a new project in Visual Studio. a) In the New Project dialog, select Console Application under Visual C#. This will create the project file structure and files (including Program.cs, which you must delete.) b) Select Project\Add Reference. In the Add Reference dialog, select the Browse tab. Use the file controls to navigate to the Dynamics AX client\bin folder. c) Select Microsoft.Dynamics.BusinessConnectorNet.dll, then select OK. This makes the .NET Business Connector accessible to the project. Select Project\Add Existing Item, and choose HelloWorldBC.cs. d) Press F5 to build and run the project. A console window will appear and display the output from the program being run. e) Repeat the above steps for the other code samples. Each program has its own main method, hence they cannot all be in the same project. You must delete the current sample before loading and running the next one. Последний раз редактировалось kornix; 29.10.2010 в 10:25. |
#4 |
kornix, никто не спорит что эти примеры полезны.
Полезность этого топика для рядового участника форума на самом деле приближается к нулю. Как вы предполагаете находить ответы на мучащие вопросы? По каким ключевым словам? По словосочетанию "полезный пример"?
#5 |
![]() Ключевые слова я бы предложил такие "примеры разработки DAX2009"
#6 |
перевели стрелки
![]() а что там за примеры внутри? |
#7 |
Да выложите в "DAX: База знаний и проекты " ... кому надо тот разберётся.
#8 |
да не будем мы выкладывать в базу знаний и проекты. это устаревший механизм. он будет отменен. ставьте теги. вопрос - КАКИЕ ИМЕННО? 2. не превращайте форум в помойку. нафига заставлять читателей разбираться в каких-то левых и подозрительных сетапах? нафига заставлять людей брать какие-то левацкие проекты да еще и заставлять РАЗБИРАТЬСЯ в них. если скачали, разобрались, СОВЕТУЕТЕ другим. ну сделайте доброе дело - напишите пару слов на понятном языке что это такое. 3. поищите аналогичные ветки. сделайте ссылки оттуда. |
| За это сообщение автора поблагодарили: kornix (1). | |
#9 |
какая именно книга подразумевается? korinx, огромное спасибо, что что-то обнаружили и предлагаете выложить. можно я попрошу вас, как автора ветки, сделать нормальное человеческое описание (желательно на русском)? Что это за сетапы? К чему они? Что содержат? Как выложенные XPO соотносятся с этими сетапами? Что содержат XPO? И tricky абсолютно прав - на какие вопросы отвечают эти XPO? Если считаете нужным, то начните новую ветку и правильным описанием. |
#10 |
#11 |
Сообщение от kornix
Это новая книга по разработке, которую я пытался где-нибудь скачать, но нашел только здесь. Правда её на этом сайте можно только читать
![]() Вышла книга «Inside Microsoft Dynamics AX 2009» то же самое для ax4 Inside Dynamics AX 4.0 - Available online for download |
| Теги |
| ax2009, download, законченный пример, полезное, скачать (download) |
| Опции просмотра | |
