Согласен думаю по коду будет проще понять в чем проблема:
Код: using System; using System.Collections.Generic; using System.Linq; using System.Text; using Microsoft.Win32; using SDK = Microsoft.Crm.Sdk; using pluginUpdateKursperescheta.CrmSdk; namespace pluginUpdateKursperescheta { public class onUpdateKp : SDK::IPlugin { public void Execute(SDK.IPluginExecutionContext context) { CrmAuthenticationToken token = new CrmAuthenticationToken(); token.AuthenticationType = 0; token.OrganizationName = context.OrganizationName; CrmService service = new CrmService(); RegistryKey regkey = Registry.LocalMachine.OpenSubKey("SOFTWARE\\Microsoft\\MSCRM"); service.Url = String.Concat(regkey.GetValue("ServerUrl").ToString(), "/2007/crmservice.asmx"); service.CrmAuthenticationTokenValue = token; service.UseDefaultCredentials = true; //----------------------------------------------------------------------------------------- SDK::DynamicEntity currentKp = context.PostEntityImages["KpIm"] as SDK::DynamicEntity; try { if (currentKp.Properties.Contains("new_kursperesheta")) { ColumnSet cols = new ColumnSet() { Attributes = new string[] { "new_wholeamount" } }; ConditionExpression cond = new ConditionExpression() { AttributeName = "quoteid", Operator = ConditionOperator.Equal, Values = new object[] { ((SDK::Key)currentKp.Properties["quoteid"]).Value } }; FilterExpression filt = new FilterExpression() { Conditions = new ConditionExpression[] { cond } }; QueryExpression query = new QueryExpression() { ColumnSet = cols, EntityName = EntityName.quotedetail.ToString(), Criteria = filt, }; BusinessEntity[] buss = service.RetrieveMultiple(query).BusinessEntities; decimal wholeamount = 0; foreach (var item in buss) { wholeamount += ((quotedetail)item).new_wholeamount.Value; } ColumnSet colsTemp = new ColumnSet() { Attributes = new string[] { "new_temp_salesorderid" } }; ConditionExpression condTemp = new ConditionExpression() { AttributeName = "new_quoteid", Operator = ConditionOperator.Equal, Values = new object[] {((SDK::Key)currentKp.Properties["quoteid"]).Value } }; FilterExpression filTemp = new FilterExpression() { Conditions = new ConditionExpression[] { condTemp } }; QueryExpression queryTemp = new QueryExpression() { ColumnSet = colsTemp, EntityName = EntityName.new_temp_salesorder.ToString(), Criteria = filTemp }; BusinessEntity[] bussTemp = service.RetrieveMultiple(queryTemp).BusinessEntities; if (bussTemp.Length > 0) { new_temp_salesorder tempSales = new new_temp_salesorder(); tempSales.new_temp_salesorderid = new Key() { Value = ((new_temp_salesorder)bussTemp[0]).new_temp_salesorderid.Value }; tempSales.new_quoteid = ((SDK::Key)currentKp.Properties["quoteid"]).Value.ToString(); tempSales.new_totallineitemamount = new CrmMoney() { Value = wholeamount }; tempSales.new_discountamount = new CrmMoney() { Value = wholeamount - (wholeamount * ((SDK::CrmDecimal)currentKp.Properties["discountpercentage"]).Value / 100) }; tempSales.new_totaltax = new CrmMoney() { Value = tempSales.new_discountamount.Value * Convert.ToDecimal(0.18) }; tempSales.new_totalamount = new CrmMoney() { Value = tempSales.new_totaltax.Value + tempSales.new_discountamount.Value }; service.Update((BusinessEntity)tempSales); } else { new_temp_salesorder tempSales = new new_temp_salesorder(); tempSales.new_temp_salesorderid = new Key(); tempSales.new_name = ((SDK::Key)currentKp.Properties["quoteid"]).Value.ToString(); tempSales.ownerid = new Owner() { Value = ((SDK::Lookup)currentKp.Properties["createdby"]).Value }; tempSales.new_quoteid = ((SDK::Key)currentKp.Properties["quoteid"]).Value.ToString(); tempSales.new_totallineitemamount = new CrmMoney() { Value = wholeamount }; tempSales.new_discountamount = new CrmMoney() { Value = wholeamount - (wholeamount * ((SDK::CrmDecimal)currentKp.Properties["discountpercentage"]).Value / 100) }; tempSales.new_totaltax = new CrmMoney() { Value = tempSales.new_discountamount.Value * Convert.ToDecimal(0.18) }; tempSales.new_totalamount = new CrmMoney() { Value = tempSales.new_totaltax.Value + tempSales.new_discountamount.Value }; // тут падает service.Create((BusinessEntity)tempSales) Cannot call 'pluginUpdateKursperescheta.CrmSdk.CrmService.Create(pluginUpdateKursperescheta.CrmSdk.BusinessEntity)' because it is a web method. service.Create((BusinessEntity)tempSales); } } } catch (System.Web.Services.Protocols.SoapException ex) { throw new SDK::InvalidPluginExecutionException( String.Format("An error occurred in the {0} plug-in.", this.GetType().ToString()), ex); } } } } Последний раз редактировалось Krom; 09.08.2010 в 10:58. |
Код: service.Create((BusinessEntity)tempSales);
Опыт позволяет ошибаться гораздо увереннее. |
Проблему, к сожалению, это не решает.
Возможно и лишнее |
#4 |
Не очень понятно, а накой вы в плагине таким вот способом создаете экземпляр сервиса, почему не делаете так:
X++: ICrmService service = context.CreateCrmService(true); И как регистрируете плагин, на какой событие, какой сущности и что в плане синхронности? |
#5 |
Да тут вообще жуткая каша из неймспейсов.
Надо было пользоваться либо только классами веб-сервиса, либо (что правильнее) только Microsoft.Crm.Sdk. А как сейчас это компилится, я даже не представляю. ![]()
#6 |
Ошибка была тут:
tempSales.ownerid = new Owner() { Value = ((SDK::Lookup)currentKp.Properties["createdby"]).Value }; Понял, что если выдает ошибку такого типа, значит какой-то атрибут не нравится. По поводу неймспейсов: их всего 2. Web Service тянет кастомные сущности. Честно говоря по-другому я не умею. Когда-то показали такую схему, так и работаю Если покажите аналогичный функционал, используя только Microsoft.Crm.Sdk буду очень благодарен ![]() |
#7 |
Чайный пьяница
Сообщение от Krom
![]() Ошибка была тут:
Опции просмотра | |
