Старый 29.07.2009, 22:40   #7
ZVV is offline
ZVV
MCITP
Oracle
1,006 / 246 (11) ++++++
DAX 2009 + MS SQL:
static void Job3(Args _args)
    Query       q = New Query();
    QueryBuildDataSource qbds;
    QueryRun    qr;
    SysDictTable    dictTable = new SysDictTable(tableNum(InventTable));
    int i;
    qbds = q.addDataSource(tableNum(InventTable));
    for (i=1; i<=100; i++)
        qbds.addSortField(dictTable.fieldCnt2Id(i));
    info(qbds.toString());
    qr = New QueryRun(q);
    while (qr.next())
        info("In");
        break;
PHP код:
Info    Сообщение (22:39:55)    SELECT FROM InventTable ORDER BY InventTable.ItemGroupId ASCInventTable.ItemId ASCInventTable.ItemName ASCInventTable.ItemType ASCInventTable.PurchModel ASCInventTable.Height ASCInventTable.Width ASCInventTable.SalesModel ASCInventTable.CostGroupId ASCInventTable.ReqGroupId ASCInventTable.EPCManager ASCInventTable.PrimaryVendorId ASCInventTable.NetWeight ASCInventTable.Depth ASCInventTable.UnitVolume ASCInventTable.BOMUnitId ASCInventTable.ItemPriceToleranceGroupId ASCInventTable.Density ASCInventTable.Dimension ASCInventTable.CostModel ASCInventTable.UseAltItemId ASCInventTable.AltItemId ASCInventTable.Intracode ASCInventTable.ProdFlushingPrincip ASCInventTable.MinimumPalletQuantity ASCInventTable.PBAItemAutoGenerated ASCInventTable.WMSArrivalHandlingTime ASCInventTable.BOMManualReceipt ASCInventTable.StopExplode ASCInventTable.Phantom ASCInventTable.IntraUnit ASCInventTable.BOMLevel ASCInventTable.BatchNumGroupId ASCInventTable.AutoReportFinished ASCInventTable.OrigCountryRegionId ASCInventTable.StatisticsFactor ASCInventTable.AltConfigId ASCInventTable.StandardConfigId ASCInventTable.ProdPoolId ASCInventTable.PropertyId ASCInventTable.ABCTieUp ASCInventTable.ABCRevenue ASCInventTable.ABCValue ASCInventTable.ABCContributionMargin ASCInventTable.CommissionGroupId ASCInventTable.Configurable ASCInventTable.SalesPercentMarkup ASCInventTable.SalesContributionRatio ASCInventTable.SalesPriceModelBasic ASCInventTable.DEL_MinAverageSettle ASCInventTable.NameAlias ASCInventTable.ProdGroupId ASCInventTable.projCategoryId ASCInventTable.grossDepth ASCInventTable.grossWidth ASCInventTable.grossHeight ASCInventTable.standardPalletQuantity ASCInventTable.qtyPerLayer ASCInventTable.sortCode ASCInventTable.ConfigSimilar ASCInventTable.SerialNumGroupId ASCInventTable.DimGroupId ASCInventTable.ModelGroupId ASCInventTable.ItemBuyerGroupId ASCInventTable.TaxPackagingQty ASCInventTable.WMSPalletTypeId ASCInventTable.OrigStateId ASCInventTable.DEL_StopExplodePrice ASCInventTable.WMSPickingQtyTime ASCInventTable.TaraWeight ASCInventTable.PackagingGroupId ASCInventTable.ScrapVar ASCInventTable.ScrapConst ASCInventTable.StandardInventColorId ASCInventTable.StandardInventSizeId ASCInventTable.ItemDimCombinationAutoCreate ASCInventTable.ItemDimCostPrice ASCInventTable.ItemIdCompany ASCInventTable.AltInventSizeId ASCInventTable.AltInventColorId ASCInventTable.ForecastDMPInclude ASCInventTable.PalletTagging ASCInventTable.ItemTaggingLevel ASCInventTable.FiscalLIFOAvoidCalc ASCInventTable.FiscalLIFONormalValue ASCInventTable.FiscalLIFOGroup ASCInventTable.FiscalLIFONormalValueCalc ASCInventTable.BOMCalcGroupId ASCInventTable.PBAItemConfigurable ASCInventTable.PBAInventItemGroupId ASCInventTable.PBAHideDialog ASCInventTable.PBAHideApproval ASCInventTable.PBAAutoStart ASCInventTable.PBAMandatoryConfig ASCInventTable.NRTaxGroup_LV ASCInventTable.Packing_RU ASCInventTable.AssetGroupId_RU ASCInventTable.AssetId_RU ASCInventTable.IntrastatExclude_LT ASCInventTable.IntrastatWeight_CZ ASC
Info    Сообщение
(22:39:55)    In
Zhirenkov Vitaly
ax3.0, группировка, отчет
Ограничение на количество сессий одного пользователя Raven Melancholic DAX: Администрирование 24 25.05.2011 08:58
Ограничение количества одновременных подключений под одним логином polygris DAX: Программирование 7 16.05.2008 13:21
Ограничение на количество фин. аналитик sever DAX: Программирование 0 13.01.2004 08:03
количество страниц отчета lexa DAX: Программирование 1 04.08.2003 14:21
Часовой пояс GMT +3, время: 14:24.
