Старый 04.05.2009, 14:05   #2
dax-lessons: Get the Exchange Rates for the given Currency using X++
Источник: http://dax-lessons.spaces.live.com/B...FCD1!154.entry
I did MSN search and found a public web service; webservicex.net that provides a public currency converter web service.
This code snippet accesses a public web service to get the exchange rate for a given currency using x++.
static void GetExchangeRates(Args _args)
    com com = new com('microsoft.xmlhttp');
    com com1;
    XMLDocument xmlDoc;
    Dialog exchDialog = new Dialog("Exchange Rates");
    DialogField   fromField;
    DialogField   ToField;
    str                 url;
    fromField = exchDialog.addField(Types::String, 'Base Currency');
    fromField.value(CompanyInfo::find().CurrencyCode);
    ToField   = exchDialog.addField(Types::String, 'To Currency');
    if(exchDialog.run())     {         url = "http://www.webservicex.net/CurrencyConvertor.asmx/ConversionRate?";
        url += "FromCurrency=" +strupr(fromField.value())+"&ToCurrency="+strupr(ToField.value());
        com.open("get",url, false);         com.send();         com1 = com.responsexml();         xmlDoc = XmlDocument::newXml(com1.xml());         info("1 "+fromField.value() + " = " +xmlDoc.getNamedElement('double').text() + " " +ToField.value());     }  }For more information on the web service, methods and the supported currencies Click here
blog, x++
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 08.08.2008 19:06
dax-lessons: Problem when creating a dynamic form with ActiveX control & Solution :) Blog bot DAX Blogs 0 30.04.2008 16:05
dax-lessons: Weather forecasting using X++ Blog bot DAX Blogs 2 25.04.2008 12:00
dax-lessons: Stopping and starting services using x++ Blog bot DAX Blogs 0 31.03.2008 16:05
dax-lessons: Active directory in Axapta Blog bot DAX Blogs 0 27.08.2007 23:00
Часовой пояс GMT +3, время: 12:48.
