Старый 22.01.2009, 12:05   #1
palleagermark: Adding simple display fields on VS reports
Источник: http://palleagermark.blogspot.com/20...lds-on-vs.html
One thing I feel is missing from the documentation for AX Visual Studio reports is a simple explanation or demo of how to create an od school display field in a report.
I could figure out that a DataMethod was needed but it took me some time to figure out how connect the method with a field on the report and how to pass parameters to the DataMethod.
You add a datamethod like this:
[DataMethod(), AxSessionPermission(SecurityAction.Assert]
public static string DataMethod1(string itemId)
string demoString = '(' + itemId + ')';
return demoString;
Then add a field to your design, and in the Expression editor for the field add the code to call your datamethod:
=DataMethod1(Fields!ItemId.Value)
palleagermark: Adding new financial dimensions to AX Blog bot DAX Blogs 1 17.02.2009 13:03
axStart: Please keep the AOT reports in Dynamics AX next release alive Blog bot DAX Blogs 2 13.12.2008 12:18
axaptapedia: Display method Blog bot DAX Blogs 0 29.08.2007 16:30
axcoder: Unwanted fields fetching when selecting by unique index Blog bot DAX Blogs 5 31.07.2007 19:56
Как в Design из Reports выводить многострочные Fields типа String? bolt DAX: Программирование 1 19.02.2004 16:57
Часовой пояс GMT +3, время: 13:13.
