Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 15.01.2009, 12:27   #1
bakingtheiron is offline
bakingtheiron
Сообщение от coolibin Посмотреть сообщение
It seems like it always works that way. I am not sure about ax4, but in ax3 you could change the command
hasPrefix = false;
to
hasPrefix = true;
in a method Classes\Info\viewBuild
It will force infolog to appear as a tree in any case.
This forces the tree view like you said, but I'm unsure of what my superiors will think of it.
addone more setPrefix call in the "root" method. For example if you are calling the method from a RunBase descendant, add setPrefix(this.caption()) to the start of the run() method
This is being called via a validateWrite() on a table. I wish to keep all of this on the table.
Many thanks to both of you, I didn't have much hope of getting around this problem.
I cheated with my solution:
warning('warning message');
setPrefix(' ');
//then the while, etc
This works, and doesn't look too bad. Its only purpose being to warn the end user.
Thanks again guys
Последний раз редактировалось bakingtheiron; 15.01.2009 в 12:39.
gatesasbait: How to temporarily suppress infolog messages in Dynamics Ax (deux) Blog bot DAX Blogs 7 28.01.2009 17:45
DAX 4.0: infolog & workspaceNum petergunn DAX: Программирование 3 22.01.2009 11:32
Developer notes: Write InfoLog to database Blog bot DAX Blogs 0 03.05.2008 08:16
axaptafreak: Send message to online user in Dynamics AX 4.0 (quick & dirty) Blog bot DAX Blogs 0 12.04.2007 16:10
casperkamal: Customizing Infolog through SysInfoAction Blog bot DAX Blogs 0 30.01.2007 20:20
Часовой пояс GMT +3, время: 12:28.
