Старый 18.04.2008, 12:52   #14
longson is offline
longson
Вот код этой выгрузки
static void CustCMRForm_ES(CustInvoiceJour CIJ, CurrencyCode _nCCode='EUR'){
    str s;
    QueryRun                queryRun;
    Query                   query;
    QueryBuildDataSource    qbdsITrans;
    QueryBuildDataSource    qbdsInventDim;
    QueryBuildRange         qbr;
    CustInvoiceJour  IJour;
    SalesTable  SalesTable;
    CustTable Vendor,Customer;
    InventSerial ISerial;
    CustInvoiceTrans ITrans,ITrans1;
    InventTrans InventTrans;
    InventDim InventDim,InventDim1;
    RContractTable RCT;
    InventTable ITable;
    CurrencyCode CCode,nCCode=_nCCode;
    Address ADR;
    Amount sSum=0, sVAT=0,wN=0,wB=0,wNl=0,wBl=0;
    Qty sQty=0;
    counter i,p,start;
    counter RollCount=0,PalletCount=0, lRollCount=0,lPalletCount=0;
    RNumDateInWordConverter converter = RNumDateInWordConverter::construct('en-us');
    boolean ExOut=false;
    #ExcelExport
    ComExcelDocument_RU excl=new ComExcelDocument_RU();
    Str Amount2Text(real Amount, CurrencyCode Curr){
     return converter.numeralsToCurrency(Amount,Curr);
    Str Qty2Text(real Amount){
     return strfmt('%1 kg %2 g',converter.numeralsToTxt( abs(Amount) - frac(abs(Amount))),int2str(decround(frac(abs(Amount)) * 100, 2)));
    Str RC(int r,int c){
     return ComExcelDocument_RU::numtonamecell(c,r);//strfmt('R%1C%1',r,c);
    Str RC_(int r,int c){
     return strfmt('R[%1]C[%1]',r,c);
    converter.initCurrencyAndConnection();
    excl.newFile(#ExcelTemplateDir+#ExCMR_ES);            // -= ????????? ?????? =-
    excl.visible(false);
    IJour=CustInvoiceJour::findFromCustInvoiceTrans(CIJ.SalesId,CIJ.InvoiceId,CIJ.InvoiceDate,CIJ.numberSequenceGroup);// ????
    CCode=IJour.CurrencyCode?IJour.CurrencyCode:CompanyInfo::find().CurrencyCode;
    SalesTable=SalesTable::find(CIJ.SalesId);                          // ?????
    Vendor=CustTable::find(SalesTable.JuridicalPerson_NV);         // ????????? - ???? ??????????? ????
    Customer=CustTable::find(SalesTable.CustAccount);              // ??????
    p=1;
    RCT=RContractTable::find(RContractPartnerType::Cust,IJour.RContractCode,IJour.RContractAccount);
    excl.insertValue('Contract',RCT.RContractNumber,p);   // ???????
    excl.insertValue('ContractDate',date2StrUsr(RCT.ContractDate),p);  // ???? ????????
    excl.insertValue('ContractValidityDate',date2StrUsr(RCT.ContractEndDate),p);  // ???? ????????? ????????
    excl.insertValue('NumberSpecification',SalesTable.ExtNo_Spec_REP,p);      // ????????????
    excl.insertValue('DateSpecification',date2StrUsr(SalesTable.createdDate),p);      // ???? ??????????
    excl.insertValue('CustomerAdressIndex',Customer.invoiceAddress().ZipCode,p);      // ?????? ??????????
    excl.insertValue('CustomerCountryAdress',Customer.invoiceAddress().Country,p);      // ?????? ??????????
    excl.insertValue('CustomerCityAdress',Customer.invoiceAddress().City,p);      // ????? ??????????
    excl.insertValue('CustomerStreetAdress',Customer.invoiceAddress().Street,p);      // ????? ??????????
    excl.insertValue('CustomerHouseAdress',strfmt('%1 %2 %3',Customer.invoiceAddress().Estate_RU,
                                                             Customer.invoiceAddress().Building_RU,
                                                             Customer.invoiceAddress().Flat_RU),p);      // ??? ??????????
    excl.insertValue('Customer',Customer.Name);          // ??????????
    excl.insertValue('DeliveryPlace',Global_REP::CustExtAdr(Customer,Customer.invoiceAddress()),p);          // ????? ??????????
    excl.insertValue('DateShipping',date2strusr(IJour.InvoiceDate)/*systemdateget()*/,p);   // ???? ????????
    excl.insertValue('NumberShipping',IJour.InvoiceId,p);   // ????? ????????
    excl.insertValue('Amount',Currency::curAmount2CurAmount(IJour.InvoiceAmount,CCode,nCCode),p);     // ?????
    excl.insertValue('AmountStr',Amount2Text(Currency::curAmount2CurAmount(IJour.InvoiceAmount,CCode,nCCode),nCCode),p);            // ????? ????????
    excl.insertValue('NumberAutomobile',gReport_REP::VehicleNo(IJour));// ? ??????????
    i=0;
    query  = new Query();
    qbdsiTrans   = query.addDataSource(tableNum(CustInvoiceTrans));
    qbdsInventDim   = qbdsiTrans.addDataSource(tableNum(InventDim));
    qbdsInventDim.relations(true);
    qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,SalesId));
    qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,InvoiceId));
    qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,InvoiceDate));
    qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,numberSequenceGroup));
    qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,ItemId));
    qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,SalesUnit));
    qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,SalesPrice));
    qbdsInventDim.addSortField(fieldnum(InventDim,InventSizeId));
    qbdsITrans.orderMode(ordermode::GroupBy);
    qbdsInventDim.orderMode(ordermode::GroupBy);
    qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,SalesId));
    qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,InvoiceId));
    qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,InvoiceDate));
    qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,numberSequenceGroup));
    qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,ItemId));
    qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,SalesUnit));
    qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,SalesPrice));
    qbdsInventDim.addSelectionField(fieldnum(InventDim,InventSizeId));
    qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,Qty),SelectionField::Sum);
    qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,lineAmount),SelectionField::Sum);
    qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,lineAmountTax),SelectionField::Sum);
    qbdsITrans.addRange(fieldNum(CustInvoiceTrans,SalesId)).value(CIJ.SalesId);
    qbdsITrans.addRange(fieldNum(CustInvoiceTrans,InvoiceId)).value(CIJ.InvoiceId);
    qbdsITrans.addRange(fieldNum(CustInvoiceTrans,InvoiceDate)).value(queryvalue(CIJ.InvoiceDate));
    qbdsITrans.addRange(fieldNum(CustInvoiceTrans,numberSequenceGroup)).value(CIJ.numberSequenceGroup);
    queryRun =  new QueryRun(query);
    while
     (queryrun.next())
      ITrans=queryrun.get(tablenum(CustInvoiceTrans));
      InventDim=queryrun.get(tablenum(inventdim));
//          select * from ITrans where ITrans.SalesId==CIJ.SalesId &&
//                                     ITrans.InvoiceId==CIJ.InvoiceId &&
//                                     ITrans.InvoiceDate==CIJ.InvoiceDate &&
//                                     ITrans.numberSequenceGroup==CIJ.numberSequenceGroup {
    wNl=0;wBl=0;lRollCount=0;lPalletCount=0;ITable=InventTable::find(ITrans.ItemId);
   while select * from ITrans1 where ITrans1.SalesId==ITrans.SalesId &&
                                     ITrans1.InvoiceId==ITrans.InvoiceId &&
                                     ITrans1.InvoiceDate==ITrans.InvoiceDate &&
                                     ITrans1.numberSequenceGroup==ITrans.numberSequenceGroup &&
                                     ITrans1.ItemId==ITrans.ItemId &&
                                     ITrans1.SalesUnit==ITrans.SalesUnit &&
                                     ITrans1.SalesPrice==ITrans.SalesPrice
    while select sum(Qty) from inventTrans join inventdim1
      group by inventserialid
      where inventtrans.inventDimId==inventdim1.inventDimId &&
            inventtrans.StatusIssue==StatusIssue::Sold &&
            inventtrans.InventTransId==iTrans1.InventTransId &&
            inventtrans.ItemId==iTrans.ItemId
            && inventdim1.InventSizeId==inventdim.InventSizeId
      RollCount++;
      lRollCount++;
      group by wmspalletid
//      wB=wB+WMSPallet::find(InventDim.wMSPalletId).GrossWeight_NV;
//      wBl=wBl+WMSPallet::find(InventDim.wMSPalletId).GrossWeight_NV;
      PalletCount++;
      lPalletCount++;
      } // while sum(qty)
     } // while ITrans1
     wN=wN+ITrans.Qty;
     wNl=wNl+ITrans.Qty;
      wB=wB+ITrans.Qty*1.04;//WMSPallet::find(InventDim1.wMSPalletId).GrossWeight_NV;
      wBl=wBl+ITrans.Qty*1.04;//WMSPallet::find(InventDim1.wMSPalletId).GrossWeight_NV;
//invoice
     start=32;p=2;
     excl.insertRow(start+i,p);
     excl.insertValue(RC(start+i,1),int2str(i+1),p);
     excl.insertValue(RC(start+i,3),strfmt('%1 ? %2 (BOPP coex)',ITable.ItemName,inventDim.InventSizeId),p);
     excl.insertValue(RC(start+i,17),ITrans.SalesUnit,p);
     excl.insertValue(RC(start+i,22),ITrans.Qty,p);
     excl.insertValue(RC(start+i,28),Currency::curAmount2CurAmount(ITrans.SalesPrice,CCode,nCCode),p);
     excl.insertValue(RC(start+i,33),Currency::curAmount2CurAmount(ITrans.LineAmount+ITrans.LineAmountTax,CCode,nCCode),p);
//detail packing
     start=24;p=3;
     excl.insertValue(RC(start+i,3),ITable.ItemGroupId,p);
     excl.insertValue(RC(start+i,7),'',p); // ???? ? ?. ?. - ?????? ????? ???????? - ?? ???????????? ??????? (??????? ??????) ?? ?????????
     excl.insertValue(RC(start+i,13),ITable.ThicknessId_NV,p);
     excl.insertValue(RC(start+i,17),inventDim.InventSizeId,p);
     excl.insertValue(RC(start+i,21),lRollCount,p);
     excl.insertValue(RC(start+i,25),lPalletCount,p);
     excl.insertValue(RC(start+i,29),ITrans.Qty,p);
     excl.insertValue(RC(start+i,34),wBl,p);
//Form A
//     start=32;p=4;
//     excl.insertValue(RC(start+i,9),strfmt('%1 ? %2 (BOPP coex) - %3 %4',ITable.itemName,inventDim.InventSizeId,iTrans.Qty,iTrans.SalesUnit),p);
//     excl.insertValue(RC(start+i,24),'\"W3920\"',p);
//Attent
     start=19;p=6;
     excl.insertValue(RC(start+i,3),strfmt('%1 ? %2 (BOPP coex)',ITable.itemName,inventDim.InventSizeId),p);
     excl.insertValue(RC(start+i,19),ITrans.SalesUnit,p);
     excl.insertValue(RC(start+i,21),ITrans.Qty,p);
     i++;
    excl.insertValue('Currency',nCCode,p);
    excl.insertValue('RollCount',RollCount,p);
    excl.insertValue('TotalPallet',PalletCount,p);
    excl.insertValue('WeightNetto',wN,p);
    excl.insertValue('WeightNettoStr',Qty2Text(wN),p);
    excl.insertValue('WeightBrutto',wB,p);
    excl.insertValue('TotalPackages','???? ??????!!!',1);
//    excl.insertValue('sQty',sQty);
//    excl.insertValue('sVAT_',sVAT);
//    excl.insertValue('sSum_',sSum);
//    excl.insertValue('sSum',Amount2Text(sSum,IJour.CurrencyCode));            // ????? ????????
//    excl.insertValue('sVAT',Amount2Text(sVAT,IJour.CurrencyCode));            // ??? ????????
    excl.visible(true);
Мониторинг состояния COM объекта axaLearner DAX: Программирование 5 10.04.2008 16:39
Работа с Excel через COM и ошибка 0x800A03EC (Range.AutoFilter) gl00mie DAX: Программирование 15 30.03.2007 18:37
Передача агументов в функцию com объекта doo DAX: Программирование 34 30.01.2007 13:14
Часовой пояс GMT +3, время: 10:57.
