#22 |
Microsoft Dynamics
Пример из Developer's Guide:
Modifying the Fetch method on a report The Fetch method is the main loop of a report. The programmer may override the fetch method if there are very special constraints on which records to show. The Fetch method can be modeled in X++ as //Create a new query to fetch the records QueryRun qr = new QueryRun(element.query()); //Open the prompt dialog if(qr.prompt()) { //The user didn't press cancel while(qr.next()) { file = qr.get(file); //For all data sources send(file); } } If you want to print only records that satisfy some special constraint that is difficult to express as a range in the query, write the code above, and only allow Send to be called if the constraint (expressed as a function by the same name in the example below) is satisfied: while (qr.next()) { file = qr.get(file); //For all data sources if(constraint()) send(file); }
You should use Bing before asking dumb questions. |
Опции просмотра | |
