Старый 27.04.2006, 15:56   #9
Recoilme is offline
Recoilme
злыдень
Аватар для Recoilme
895 / 192 (8) ++++++
Лови..
PHP код:
static void ip_vkul_testado(Args _args)
#CCADO
CCADOConnection cn = new CCADOConnection() ;
CCADORecordset          adoRecordset  = new CCADORecordset();
InventTable             inventTable;
DKL_InventTable         dklinventTable;
DKL_BaseRetailPrices    baseprice;
DKL_InventClassVarTable invclass;
VendTable               vendor;
CustTable               cust;
DKL_BrandTable          brand;
InventLocation          sklad;
str     descr;
int     KATEGORIAKOD,GRUPPAKOD,PODGRUPPAKOD,countrec,recCnt,skltype;
real    maksskidka,koefret;
int     bool,bool2,i,vendorid;
Map     invClassId = new map(Types::StringTypes::Integer);
SysOperationProgress progr  = new SysOperationProgress();
cn = new CCADOConnection();
select count(recidfrom invclass;
select count(recidfrom vendor;
select count(recidfrom cust;
select count(recidfrom brand;
select count(recidfrom inventTable;
select count(recidfrom dklinventTable;
select count(recidfrom baseprice;
recCnt invclass.RecId vendor.RecId cust.RecId brand.RecId inventTable.RecId dklinventTable.RecId baseprice.RecId;
cn.open("Provider=MSDASQL.1;Persist Security Info=False;User ID=sysdba;Data Source=iptmp");
    progr.setTotal(recCnt);
    progr.setCaption('?????????????');
    while select invclass
        progr.incCount();
        invClassId.insert(invClass.InventClassVarId,invClass.RecId);
        descr = strdel(invclass.Description,55,200);
        maksskidka = invclass.DiscLimit / 100;
        koefret = invclass.RetailPricePctKoeff / 100;
        if (invclass.LMA_LevelNum == 1)
            adoRecordset.open(strfmt("select id from z_kategoria where id = %1",CNN::quoted(invclass.RecId)),cn, #adOpenForwardOnly, #adLockReadOnly);
            if (adoRecordset.EOF())
                cn.execute(strfmt("INSERT INTO Z_KATEGORIA (KATEGORIA,ID,KOEFPRODAJ,MAKSSKIDKA) VALUES (%1,%2,%3,%4)",CNN::quoted(Descr),CNN::quoted(invclass.RecId),CNN::quoted(koefret),CNN::quoted(maksskidka)));
            else
                cn.execute(strfmt("UPDATE Z_KATEGORIA SET KATEGORIA=%1,KOEFPRODAJ=%3,MAKSSKIDKA=%4 WHERE ID = %2",CNN::quoted(Descr),CNN::quoted(invclass.RecId),CNN::quoted(koefret),CNN::quoted(maksskidka)));
            adoRecordset.close();
        if (invclass.LMA_LevelNum == 2)
            adoRecordset.open(strfmt("select id from Z_GRUPPA where id = %1",CNN::quoted(invclass.RecId)),cn, #adOpenForwardOnly, #adLockReadOnly);
                cn.execute(strfmt("INSERT INTO Z_GRUPPA (GRUPPA,ID,KOEFPRODAJ,MAKSSKIDKA) VALUES (%1,%2,%3,%4)",CNN::quoted(Descr),CNN::quoted(invclass.RecId),CNN::quoted(koefret),CNN::quoted(maksskidka)));
            else
                cn.execute(strfmt("UPDATE Z_GRUPPA SET GRUPPA=%1,KOEFPRODAJ=%3,MAKSSKIDKA=%4 WHERE ID = %2",CNN::quoted(Descr),CNN::quoted(invclass.RecId),CNN::quoted(koefret),CNN::quoted(maksskidka)));
        if (invclass.LMA_LevelNum == 3)
            adoRecordset.open(strfmt("select id from Z_PODGRUPPA where id = %1",CNN::quoted(invclass.RecId)),cn, #adOpenForwardOnly, #adLockReadOnly);
                cn.execute(strfmt("INSERT INTO Z_PODGRUPPA (PODGRUPPA,ID,KOEFPRODAJ,MAKSSKIDKA) VALUES (%1,%2,%3,%4)",CNN::quoted(Descr),CNN::quoted(invclass.RecId),CNN::quoted(koefret),CNN::quoted(maksskidka)));
            else
                cn.execute(strfmt("UPDATE Z_PODGRUPPA SET PODGRUPPA=%1,KOEFPRODAJ=%3,MAKSSKIDKA=%4 WHERE ID = %2",CNN::quoted(Descr),CNN::quoted(invclass.RecId),CNN::quoted(koefret),CNN::quoted(maksskidka)));
    progr.setCaption('??????????');
    while select vendor
Ибо зло есть лучшая сила человека. "Человек должен становиться все лучше и злее" -- так учу я. /Ф. Ницше/
Проблема с самописной DLL. VAlek DAX: Программирование 18 28.12.2008 10:37
Client Axapta 3.0 SP4 и Linux. Как запустить? Daiver DAX: Администрирование 10 28.06.2007 15:59
Вызов экспортируемой функции DLL Jabberwocky DAX: Программирование 8 12.09.2006 17:20
при вызове функции из своей DLL, вылетает ошибка Delfins DAX: Программирование 9 07.03.2006 19:29
Описание кода в Аксапте vasiliy DAX: Прочие вопросы 5 23.03.2005 12:16
Часовой пояс GMT +3, время: 13:10.
