Старый 15.05.2015, 15:11   #1
emeadaxsupport: Unable to insert data into the Channel database - String or Binary data would be truncated
Источник: http://blogs.msdn.com/b/axsupport/ar...truncated.aspx
Dynamics AX
2012 R2/R3 Retail
Description:
While inserting a Distribution package job like 1010 into the Channel database following message appears and the operation stops.
Full error message:
Microsoft.Dynamics.Retail.StoreConnect.Request.SQLHandler.ProcessSourceRequestHeaderException:
ProcessTargetRequestHeader failed due to an InvalidOperationException.
connectionString:
Data Source=743R1;Initial Catalog=POSDB;Integrated Security=True;MultipleActiveResultSets=True;Connect
Timeout=60;Encrypt=True;TrustServerCertificate=True;Application
Name="Commerce Data Exchange Async Client" --->
System.InvalidOperationException: The given value of type String from the data source cannot be
converted to type nvarchar of the specified target column. --->
System.InvalidOperationException: String or binary data would be truncated.
at
System.Data.SqlClient.SqlBulkCopy.ConvertValue(Object value, _SqlMetaData
metadata, Boolean isNull, Boolean& isSqlType, Boolean&
coercedToDataFeed)
--- End of inner exception stack trace ---
How to troubleshoot the issue:
The message “String and Binary data would betruncated”, means that the data length of a string is longer than accepted
by the field.
Validate which field is longer than accepted by
  • Copy your Channel database to the same server as your AX database
  • Change the AX database name in the script attached
  • Open a new Query on the Channel database and execute the statement
Result:
The result shows us that the Dirparytable NameAlias has a record that is 45
characters in length in the AX database, but only 20 characters are allowed in
the channel database.
tableName
ColumnName
CHANNELLEN
HQMAXLEN
DIRPARTYTABLE
NAMEALIAS
20
45
NUMBERSEQUENCETABLE
TXT
30
35
BARCODESETUP
DESCRIPTION
30
26
RETAILTENDERTYPETABLE
NAME
30
23
RETAILSIZEGROUPTABLE
DESCRIPTION
30
22
INVENTMODELGROUP
NAME
30
16
RETAILSTYLEGROUPTABLE
DESCRIPTION
30
15
CASHDISC
DESCRIPTION
30
11
The solution:
  • You can change the schema in the channel database to accept the needed input
    • Retail SDK/CreateDatabase.dll if done correctly
    • Or you can rename the value in AX to only have 20 characters
Author: Kim
Truelsen
Date:
15/5-2015
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
emeadaxsupport: Unable to close shift due to records in Offline database Blog bot DAX Blogs 0 20.08.2013 15:11
emeadaxsupport: AX 2012 Retail: Creating Offline Database fails Blog bot DAX Blogs 0 14.05.2012 17:11
emeadaxsupport: Multiple database data files, table partitioning using multiple file groups… and Microsoft Dynamics AX 2009 Blog bot DAX Blogs 3 04.10.2011 16:30
String or binary data would not be truncated DreamCreator DAX: Программирование 4 22.02.2005 03:06
Часовой пояс GMT +3, время: 18:11.
