Старый 11.08.2016, 06:14   #1
organicax: WMS Mobile Device – pick and pack parameter
Источник: https://organicax.com/2016/08/10/wms...ack-parameter/
If you have situations where you have work that needs to be consolidated by the picker because it’s related to the same shipment you might want to investigate the pick and pack parameter on the mobile device menus. Take an example where you release an order to the warehouse but not long after a customer calls in and wants to increase the order. So you release the extra quantity to the warehouse. The sales team calls the warehouse. So the shipment can be combined but there is two pieces of work out there. When the workers goes to pick they could pick both the work and combine them on the device with the pick and pack parameter.
Here is a quick overview.
AX2012 R3 CU10.
Cheers
Lachlan
Filed under: Warehouse management
DynamicsAxSCM: What’s new in CU10 for WMS and TMS Blog bot DAX Blogs 0 25.11.2015 13:11
Kashperuk Ivan: Tutorial: Custom work types and shipment notes on the mobile device in Warehouse management module in Dynamics AX 2012 R3 Blog bot DAX Blogs 0 01.07.2015 19:11
DynamicsAxSCM: What’s new in CU8 for WMS and TMS? Blog bot DAX Blogs 0 20.11.2014 04:16
kurthatlevik: Turn your Dynamics AX WMS from ‘Where’s My Stuff’ to an actual ‘Warehouse Management System’ Blog bot DAX Blogs 0 21.11.2013 19:11
Часовой пояс GMT +3, время: 23:04.
