organicax: Overview of editing the CSS style sheet for the warehouse mobile device
Источник: http://organicax.com/2016/03/24/over...mobile-device/
============== In a previous post we looked at the basic label color display for the warehouse mobile device. If you wanted to do something more advanced then you can edit the CSS style sheet. This isn’t a user task and you are best to get someone that has some experience editing style sheets for web applications. It’s also worth noting as I’ll point out in the video some of the label colors are injected as an in-line style from the application. So these few labels you will have to change in the warehouse mobile device text colors setup. You will have to co-ordinate these with the CSS change you make to those collections. Here is a quick walk through. AX2012 R3 CU9. Cheers Lachlan Filed under: Uncategorized, Warehouse management Источник: http://organicax.com/2016/03/24/over...mobile-device/
