Старый 09.08.2013, 16:11   #1
emeadaxsupport: Quick tip - Unretrieved value in a field in a form
Источник: http://blogs.msdn.com/b/axsupport/ar...in-a-form.aspx
If you run into the problem in Dynamics AX2012 that a form is displaying a field with the message 'Unretrieved value' and you can neither see or edit the contents of the field, try to stop and restart the AOS service and see if the issue is not resolved. Stopping and starting the AOS will refresh the join and make the field accessible.
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
emeadaxsupport: Wrong data shown in the grid, if the table field is an Int 64 and the form control is an IntEdit instead of an int64edit. Blog bot DAX Blogs 3 22.07.2010 18:00
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Microsoft Dynamics CRM Team Blog: Quick Tip: Passing CRM Form values to an IFrame Blog bot Dynamics CRM: Blogs 0 12.09.2008 02:05
Часовой пояс GMT +3, время: 20:27.
