Banned
Why is the approach taken to de-integrate everything in Ax?
**** выделено отсюда AXDevCenter Headlines: See the Future of X++ and .NET *****
Хочется процитировать один комментарий: Цитата:
Why is the approach taken to de-integrate everything in Ax? It's strongest point is the fact that you have a single tool-set for everything and now the direction seems to be moving away from that. When you rely on other tools (eg SSRS) you're effectively introducing a new system and interface, and there will always be a disconnect between the two. Is it just to incorporate as many technologies as possible as opposed to actually improving developer productivity? I am honestly, yet to hear a solid technical argument for this approach as opposed to marketing based 'xxx is the future'. The day-to-day issues that come up with installing all of these systems (SSRS, Sharepoint, EP) and the problems that occur from differing versions/service packs/etc are constant and very frustrating. And at this point (V2009) the tools and integration are not as solid or reliable as one would hope. In terms of 'dropping X++ reports' - I shudder to think what the SSRS implementation of something like financial statements or the highly procedural/configurable reports would be like. I'm generally interested in the overall approach and reasoning as this is my day-to-day work. |
| За это сообщение автора поблагодарили: AlGol (1), glibs (2). | |
Дело не в "single tool-set", а "new system and interface" В том же Навике тоже есть новые отчеты и они тоже сделаны на SSRS. Но сделана действительно "бесшовная" интеграция, пользователь не замечает что он в другом приложении - продолжает пользоваться своими любимыми и привычными фильтрами, окно похоже на окно Навижина и т.п... (картинки напоминают на детскую игру "найди знакомый предмет на картинке". Попробуйте найти интерфейс SSRS на картинках )![]() ![]() диалоговое окно для ввода параметров и фильтров ![]() см. http://navision.mazzy.ru/lib/nav2009-reports/ т.е. дело не в том, что не стоит использовать различные инструменты... Дело в том, что интерфейс к ним должен быть единообразным |
![]() Я же ссылку приводил http://navision.mazzy.ru/lib/nav2009-reports/ Почитайте как оно со стороны разработчика. Разработчикам Навика проще. В Навике нет такой офигительной штуки, как расширенные типы и relations на этих типах. Поэтому разработчикам Навика проще перейти на VS - и там, и там вручную поля и связи ставить надо. Разработчикам Аксапты - сложнее. Меня, например, просто наизнанку выворачивает от того, что VS не подхватывает связи, метки, ширину поля и прочее из EDT. Нне могу заставить заниматься такими вещами вручную. Очень надеюсь, что подобное получит развитие... |
Сообщение от fed
Просто кто-то неплохо пиарит себя внутри Майкрософт рассказывая про ролевой интерфейс, разработку управляемую моделями, интеграцию с .net, облачные вычисления и том как это сильно повышает динамичность бизнеса (c). С потребностями рынка это не связано, но получить пару повышений по службе за счет этого - очень даже можно...
![]() Цитата:
| За это сообщение автора поблагодарили: mazzy (2). | |
Майкрософт использует Great Plains в качестве базовой системы для развития своих технологий. GP технологически, функционально и интерфейсно слабее даже Навижина, не говоря уже об Аксапте. В результате то, что для GP выглядит как Wow-эффект, для Аксапты и Навижина выглядит регрессом. 1. Так навигационные списки с отбором по одному полю из списка - явный регрес для Аксапты и в большой степени для Навижина. 2. В GP отсутствовал модуль CRM - сделали интеграцию с MS CRM для всех систем. Для пользователей GP - ура-ажиотаж и новый функционал. Для пользователей Аксапты и Навижина сплошной гемор, ад, треш и угар, поскольку в них есть свой модуль CRM (который Майкрософту пришлось передвинуть в Advanced-лицензию) и что теперь делать - совершенно непонятно. По-моему, то же самое происходит и с SSRS с ролевыми центрами. Кстати, несмотря ни на что, в Навике его сделали очень и очень достойно и безо всяких усложнений. Поэтому видимо торопиться не стоит. "Еще 1832 ведра, и золотой ключик у нас в кармане" (С)
На мой взгляд - бесполезно искать за происходящим какой-то рациональный контекст. Почитай того же Майка Эренберга. Просто кто-то неплохо пиарит себя внутри Майкрософт рассказывая про ролевой интерфейс, разработку управляемую моделями, интеграцию с .net, облачные вычисления и том как это сильно повышает динамичность бизнеса (c). С потребностями рынка это не связано, но получить пару повышений по службе за счет этого - очень даже можно... P.S. Кстати почитал биографию Эренберга. Пишут: "As CTO at Marcam, Ehrenberg drove the development of the first ERP product for Windows NT, deeply architected for the Microsoft platform. " Дальше ищем в Гугле про Marcam. "In 1994 Marcam began developing it’s next generation product for platforms beyond IBM’s AS/400. This product, known as Protean, was written using Object Oriented Programming. In May of 1999, facing the downturn from the Y2K crash, and many technology challenges stemming from the Proteon project, Marcam threw in the towel and sold out to Invensys, Plc." В общем - у чувака большой опыт в разработке ERP с использованием объектно-ориентированных технологий. Один продукт этих технологий уже не выдержал
Последний раз редактировалось fed; 05.04.2010 в 11:38. |
Member
Тоже согласен. Система усложняется. И для консультанта, и для разработчика, и для пользователя. Под вопросом идея тонкого клиента (работа по модему, пусть с тормозами). Большие проблемы с преемственностью. А главное за всем этим видится маркетинг, а не забота о пользователях (имею в виду конечных пользователей, т.е. корпоративного клиента, который платит за Аксапту деньги, а не бухгалтерш и кладовщиков, хотя их это тоже касается, по-моему).
С уважением, glibs® |
#9 |
#10 |
В старину (до выхода 4ой версии) официальные требования к каналу между AOS и клиентом были такими:
64Kbit на 10 клиентов, задержки в канале - 50ms. (конечно это не означало что один клиент сможет работать на канале шириной 6.4KBit, просто из 10 клиентов в данный момент времени с системой обычно работало 2-3 и на них хватало этих 64Кбит). На практике - эти требования конечно были малость занижены. Для комфортной работы надо было 128Кбит на 10 пользователей и 20ms задержки в канале. С переходом Аксапты под крыло микрософт требования к ширине канала возросли до 100MBit, а к задержке в канале - до "менее 5ms". |
| За это сообщение автора поблагодарили: virtuoso (1). | |
#11 |
Member
Просто по тому, как сейчас происходит интеграция (с чем только можно, лишь бы только побольше интеграции, при этом убрать из системы то, что было), у меня складывается впечатление, что мало кто из принимающих решение знает/помнит и понимает целый ряд технологий, которые были заложены в систему основателями. К моему великому сожалению многие уникальные идеи не только не получили развития, но и были затоптаны во благо интеграции с продуктами MS.
#12 |
Member
Сообщение от glibs
многие уникальные идеи не только не получили развития, но и были затоптаны ... С учетом описанной выше оговорки у меня еще сложилось впечатление, что в то время как многое в Аксапте рискует исчезнуть во имя нового общего там интерфейса... некоторые технологии успешно взял на вооружение 1С. Впрочем, инсайдерской информацией я не обладаю. Посмотрим, что будет дальше. Я слышал отзывы нескольких клиентов, перешедших с 3.0 на 5.0. Общее мнение было: "Бе". Ax32.exe утяжеляется. Требования к ресурсам растут. Много нового функционала пишется так, что на тонких каналах будет тормозить (сама манера формы рисовать имеется в виду).
#13 |
По поводу интеграции - мне кажется, на эту тему более чем исчерпывающе выразились тут: Peter Villadsen and Gustavo Plancarte: X++ to MSIL
Люди часто повторяют: надо стоять на плечах гигантов, и, думаю, в вашей студии это звучало не раз, но я чувствую, что это именно то, что мы должны делать. Нам не следует самим нести все затраты, связанные с поддержкой и развитием всей инфраструктуры, когда есть такие отличные вещи, как .NET, и Visual Studio, и LINQ.
А по поводу утяжеления клиента и повышения требований к каналам... можно вспомнить того же Джоэла Спольски: Цитата:
Разработчики, которые прикладывают много усилий в оптимизацию и делают компактные и быстрые программы, однажды проснутся и обнаружат, что усилия были потрачены зря в большей или меньшей степени. Или, в крайнем случае, можно сказать, что «это не дало конкурентного преимущества в долгосрочной перспективе», если вы человек, разговаривающий как экономист.
Разработчики, которые наплевали на производительность и ринулись добавлять классные функции в свои программы, получат в долгосрочной перспективе лучшие программы. |
| За это сообщение автора поблагодарили: mazzy (2), Poleax (1). | |
#14 |
Вспоминается старый анекдот про то как Хрущев съездил в Англию и по итогам визита решил перевести СССР на левостороннее движение. Ну и для начала, в качестве эксперимента, попробовали запустить 100 автомобилей на Садовое Кольцо по левой стороне.
Просто не очень понятно - какой смысл ЧАСТЬ среды разработки мигрировать на Visual Studio и вообще микрософтовские технологии, если в принципе не понятно как на VS и .net отмигрировать такую фундаментальную технологию как технология слоев. Вот если уважаемые любители стоять на плечах гигантов объяснят мне как они собираются ее мигрировать - я перестану бухтеть. Какой вот смысл делать все эти AOD-browser для Visual Studio, переносить отчеты на SSRS и выносить отчеты на WF (от которого даже знакомые .netовцы стонут и ругаются неприлично), если не видно способа миграции всего приложения и всей среды на новые технологии ? Кстати - меня вот как-то мало волнует экономия разработчиков на разработке ядра, если это не сопровождается падением стоимости одной лицензии. Однако, как все мы знаем, стоимость лицензии с каждым годом только растет... Вот и вопрос - а нафига мне такая экономия за счет интеграции, если приходится с каждым годом больше платить за лицензию на Аксапту и больше тратить денег на дополнительные работы на внедрении, связанные с той самой интеграцией ? |
| За это сообщение автора поблагодарили: mazzy (2), AlGol (1), blokva (1). | |
#15 |
Какой вот смысл делать все эти AOD-browser для Visual Studio, переносить отчеты на SSRS и выносить отчеты на WF (от которого даже знакомые .netовцы стонут и ругаются неприлично), если не видно способа миграции всего приложения и всей среды на новые технологии ? Цитата:
В том, что используется распространенный компонент, выгода не только в том, что стоимость меньше - еще проще найти дополнения к нему и информацию по нему и глюков меньше. Цитата:
#16 |
Дык возникает вопрос - если они технологию слоев в VS и .net поддержали, то почему они об этом не пишут во всех блогах и Channel 9, а пишут про какие-то примочки к AOD и улучшения в компиляторе X++ ?
ты думаешь лиуензии продаются по себестоимости?
Вообще - забавно. В классической экономической теории, после того как товар выходит из нишевого рынка на массовый, его цена должна СИЛЬНО упасть, поскольку падает доля затрат на R&D в единице товара. (Вспомни цены LCD-мониторов 10 лет назад и сейчас). Однако, в случае Аксапты, эта цена почему-то выросла в ДВА раза.Как раз недавно знакомые, которые на старой схеме лицензирования остались, считали во сколько им лицензия на одного пользователя в 2001 году обошлась и сколько она же стоит теперь. Цитата:
Пример, пожалуйста.
Не думаю что ему человек на C# обошелся бесплатно Ну и тут еще glibs чуть выше написал. |
#17 |
#18 |
#19 |
Member
Сообщение от gl00mie
собственный протокол AOCP, заменный на RPC; ... Цитата:
собственный механизм аутентификации пользователей и шифрования их паролей, заменный на Windows-аутентификацию; ... Цитата:
собственный формат БД для хранения приложения, замененный в 6-й версии на БД Ms SQL Server; ... Цитата:
собственный движок справки, замененный на HtmlHelp; ... Цитата:
собственный "движок" для корпоративного портала, замененный на Sharepoint; ... Цитата:
когда разработку ведет сторонняя контора ... Цитата:
Разработчики, которые наплевали на производительность и ринулись добавлять классные функции в свои программы, получат в долгосрочной перспективе лучшие программы. ...
#20 |
Имхо проблема не в том, что, части технологии Ax заменяются частями стека Microsoft, а в том, что кое-где они недостаточно тесно интегрированы.
Сама по себе замена какого-то эелемента факт, скорее, позитивный - мы получаем вместо компонента, который используется ограниченным количеством пользователей в ограниченом числе сценариев вылизанный компонент, который используется массово, и у которого гораздо большие перспекстивы с точки зрения развития функциональности. Например, тот же SSRS - а нем гораздо удобнее рисовать специфичные для России табличные отчеты, сам редактор удобнее и есть множество людей, которые его знают. Проблема в том, что пока он не использует настолько же плотно модель данных AX, как родной движок. Но с другой стороны, сейчас никто не заставляет его использовать. Вот если бы вы владели компанией по разработке ПО, вы бы предпочли рарабатывать 5 движков отчетов или 1? Почему тогда не нравится два модуля ОС
| Теги |
| .net, ssrs, visual studio, workflow, как правильно, права доступа, производительность, ax2012 |
