Старый 23.09.2015, 17:11   #1
axmfg: Order picking from license plate locations
Источник: http://blogs.msdn.com/b/axmfg/archiv...locations.aspx
The hotfix in Microsoft Knowledge Base (KB) article 3094382 enables order picking from license plate locations for raw material picking. This hotfix also introduces a policy that controls the status of the material line after raw material picking has been completed.
For raw material picking, there are two picking principles: order picking and staging. The term order picking is used when the ordered quantity is being picked, whereas the term staging is used when the full quantity on the picked license plate is being moved. Up to now, only staging from license plate locations has been possible. However, this hotfix now makes it possible to configure which of the two principles should be used for raw material picking. This policy is controlled at the item level, where a new Material picking in license plate locations field has been added on the Warehouse management FastTab.
By default, when a new product is created, the value of this field is set to Order picking. When you apply this hotfix on a customer installation, it’s important to change the value of this field to Staging for the items that are picked. Typically, these are the items that have been stored at the license plate locations.
Controlling the status on the material line after material put
A new Status after material put field has been added to the Inventory and warehouse management parameters.
The value of this field controls the status of the inventory transactions for the production material line after warehouse work for raw material picking has been completed. Up to now, the status has always been Picked.
The Picked status deducts physical on-hand inventory. However, feedback indicated that users expect to see the physical on-hand material at the input location after the warehouse work has been completed but not yet consumed by the production order. Therefore, it’s now possible to switch the Issue status between Picked and Reserved physical.
When you select Reserved physical, the material appears as physical on-hand (but reserved) inventory at the input location after warehouse work has been completed.
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
axmfg: Lean manufacturing: Picking activities and kanban line events Blog bot DAX Blogs 0 26.08.2014 21:13
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
DynamicsAxSCM: Changes in Sales and Transfer Order Picking from Microsoft Dynamics AX 4.0 to Dynamics AX 2009 Blog bot DAX Blogs 0 18.05.2009 02:05
Часовой пояс GMT +3, время: 19:02.
