Старый 17.07.2025, 12:15   #1
dynamicsnavax: Financial tags for sales order invoicing
Источник: http://dynamicsnavax.blogspot.com/20...invoicing.html
There is a new feature for Financial tags on Sales orders.
https://learn.microsoft.com/en-us/dy.../financial-tag
This feature can be enabled under the feature management.
After it is enabled, the sales order form will show a new fast tab under the header and line. It is similar to the financial dimensions but shows as a grid.
Note that the tags do not show under the posted invoice journal but the field FinTag is stamped. If you want analyse or do reports, it is possible.
The great thing about this feature is that it carries over to the voucher transactions.
Below are 2 examples I posted.
First example, I created a sales order with 2 lines and unique financial dimensions. The system splits the vouchers by financial dimension and hence the tags appear correct.
On a second example, I created a sales order with 2 lines but have the same financial dimension on them. The product sales voucher line has only the first sales order line tag.
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 13:27.
