organicax: Quality association to a production order
Источник: https://organicax.com/2017/04/08/qua...duction-order/
============== If you are producing goods you might want to inspect them as a quality check. This could be manual. But if you need a document to trigger the recording of the action then you can use the quality order with a production order. Now you could manually create a quality order but with a little setup in the quality association you can have the quality order triggered when the production is reported as finished. Here is a quick overview. AX2012 R3 CU11 Cheers Lachlan Filed under: Production control ![]() Источник: https://organicax.com/2017/04/08/qua...duction-order/
Опции просмотра | |
