Старый 13.05.2016, 10:11   #1
organicax: WMS Location profile – allow mixed items
Источник: https://organicax.com/2016/05/12/wms...s-mixed-items/
When you are setting up the warehouse in AX you will have to setup locations profiles. There is a parameter on the location profile called allow mixed items. That as it suggest will give you the options of allowing different products in the same location. This might be the case if there are some special items that you can’t mix for example.
Here is a quick overview.
AX2012 R3 CU9
Cheers
Lachlan
Filed under: Warehouse management
organicax: Purchase items using auto batch numbers – wms Blog bot DAX Blogs 0 08.03.2016 21:16
organicax: Purchasing items using manual batch numbers – wms Blog bot DAX Blogs 0 07.03.2016 23:17
organicax: WMS Allow pick location override Blog bot DAX Blogs 0 04.03.2016 23:11
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 14:31.
