Старый 29.04.2016, 09:11   #1
organicax: Copying purchase requisitions
Источник: https://organicax.com/2016/04/28/cop...-requisitions/
If you work a lot with requisitions and you often do the same requisitions with some minor changes then you can use the copy functions. There is a copy for a full requisition or you can copy lines from other documents.
Here is a quick overview.
AX2012 R3 CU9.
Cheers
Lachlan
Filed under: Procurement and sourcing
Dynamics AX Sustained Engineering: KB3023131 Accounting for Purchase charge and Stock variation Blog bot DAX Blogs 0 22.12.2014 13:11
Dynamics AX Sustained Engineering: Inconsistency in the way financial dimensions default from Purchase Requisitions when editing and transferring to a Purchase Order Blog bot DAX Blogs 0 01.03.2013 09:11
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
Часовой пояс GMT +3, время: 21:58.
