sashanazarov: Which query range should I select?!
Источник: http://sashanazarov.blogspot.com/201...-i-select.html
============== Customer asked me to figure out which "Customer account" should be selected in a query. There were three of them on the Customer invoice journal table: Apparently, there were a couple of fields that used the default label, and I found them in the following way. Selected the first "Customer account" range: ... right-clicked in the field value and selected Record Info: ... in the dialog, clicked on the Script button: ... pasted the clipboard to Notepad: The extended field ID was 65540. Then, I selected another range: ... and repeated the process. The second field ID was 81625. Finally, I selected the third Customer account range and found that it was based on the field ID 81626. So, the three field IDs for CustInvoiceJour table were found. But what were the field names? static void printFieldNames(Args _args) { print fieldId2Name(tableNum(CustInvoiceJour), fieldExt2Id(65540)); print fieldId2Name(tableNum(CustInvoiceJour), fieldExt2Id(81625)); print fieldId2Name(tableNum(CustInvoiceJour), fieldExt2Id(81626)); pause; } And the output was: Somebody did not follow the Best Practices for Table Fields: Источник: http://sashanazarov.blogspot.com/201...-i-select.html
Эти поляки!
За это сообщение автора поблагодарили: Stitch_MS (0). |
