Старый 03.02.2015, 20:13   #1
emeadaxsupport: Why does my sales order credit memo not use the correct exchange rate?
Источник: http://blogs.msdn.com/b/axsupport/ar...ange-rate.aspx
The definition of ‘correct’ can vary greatly in this situation, so instead of answering the question directly, I will list out a few potential reasons why this may happen.
Reason 1: No link to original invoice was created when the credit memo was entered
The credit line was manually entered, and was not created using the sales order header or line function to reference the original sales document. In this situation, since it is not linked to the original invoice, it is going to pick up the prevailing exchange rate for the date the credit memo is entered.
Reason 2: New exchange rates were created between the time of the invoice and the time of the credit memo
The credit memo was created using the sales order header function, and the invoice and credit memo were entered with the same dates, but new exchange rates were created between the time that the invoice was entered and the entry of the credit memo. In the customer example that I encountered, they were simply testing the functionality. Both the invoice and credit were entered with an August 28th date. When the invoice was posted, it picked up a July 20th exchange rate since that was the last rate entered. Prior to entering the credit, they populated additional exchange rates, including a rate for August 28th. As a result, the credit picked up the current rate, August 28th. In this situation, they simply need to run the ‘Foreign currency revaluation’ function so that the invoice would pick up the August 28th exchange rate as well.
Reason 3: Incorrect Accounts receivable parameters
The credit memo was created using the sales order header function, and the Accounts receivable parameter for Default settlement type for credit notes is set to ‘Designated transactions’. In the customer example that I encountered, they were expecting this option to also control the exchange rate. In this situation, the ‘Use exchange rate from source documents’ should also be marked. The default settlement type, is just going to apply to the settlement process between the invoice and credit. By also marking the ‘Use exchange rate from source documents’ option, the exchange rate used on the invoice will be copied to the credit memo.
Mike E
emeadaxsupport: Inconsistency between quantity in sales order and quantity in inventory transaction. Blog bot DAX Blogs 0 31.01.2015 17:11
emeadaxsupport: Vendor invoice - A currency to convert from is required to retrieve exchange rate information when trying to access a Vendor Invoice that is linked to a Purchase Order Blog bot DAX Blogs 0 05.12.2014 19:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
emeadaxsupport: "An exchange rate cannot be found for exchange rate type XXX between currencies YYY and ZZZ on exchange date." when you attempt to process in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 26.09.2012 07:15
dynamicsaxtraining: Sales Blog bot DAX Blogs 0 25.04.2012 03:18
Часовой пояс GMT +3, время: 03:41.
