Старый 15.01.2012, 05:17   #1
equalized: Dynamics ax take screenshots from FormControls
Источник: http://www.kevinroos.be/2010/11/dyna...-formcontrols/
Hi all,
Here is a little code snippet for you to take screen shots within a Dynamics Ax client.
public void run(FormControl _control) { str SaveToFileName; System.Drawing.Bitmap bitmap; System.Drawing.Graphics graphics; System.Windows.Forms.Screen primaryScreen; System.Drawing.Rectangle bounds; int x, y, k, l; System.Int32 width; System.Int32 height; #define.FileName('DynamicsAx_Screenshot.png') ; try { // 5 for the My Documents folder SaveToFileName = strfmt(@"%1%2",WinApi::getFolderPath(5),#FileName); primaryScreen = System.Windows.Forms.Screen::get_PrimaryScreen(); bounds = primaryScreen.get_Bounds(); [x, y, k, l] = WinApi::getWindowRect(_control.hWnd()); width = _control.widthValue(); height = _control.heightValue(); // TwC: used API CLRObject // BP Deviation Documented bitmap = new System.Drawing.Bitmap(width,height); graphics = System.Drawing.Graphics::FromImage(bitmap); graphics.CopyFromScreen(x,y,0,0,bitmap.get_Size()); bitmap.Save(SaveToFileName, System.Drawing.Imaging.ImageFormat::get_Png()); } catch { error("The file could not be saved"); // TODO make label } }
This snippets uses the size of your control and the position on your screen to create the screenshot
equalized: Dynamics ax take screenshots from FormControls Blog bot DAX Blogs 0 22.04.2011 17:11
Часовой пояс GMT +3, время: 09:54.
