Старый 08.06.2010, 19:05   #1
emeadaxsupport: Role Center is no longer showing up after installing an Application Roll-Up package
Источник: http://blogs.msdn.com/b/emeadaxsuppo...p-package.aspx
I recently came across the situation that after installing an Application Roll-Up package the Role Center page was no longer showing up in Dynamics AX 2009 and the “Home” module was also completely missing – just as if no Role Center was specified. The Role Center URL was however configured and could be manually accessed from Internet Explorer.
The root cause of the issue was, that after installing the Application Roll-Up the Upgrade Checklist was not completed in all steps. After completing all steps of Upgrade Checklist and restarting the Dynamics AX 2009 Client, the Role Center showed up again.
In the Table method EPGlobalParameters::homepageSiteURL Dynamics AX is explicitly checking if the Upgrade Checklist was completed and if not the URL the Role Center is not returned.
ax2009, role center
emeadaxsupport: Some charts in the Role Center show a wrong axis scale 0-0-0-1-1-1 Blog bot DAX Blogs 0 27.05.2010 15:05
emeadaxsupport: Dynamics AX Reporting Services Reports does not refresh after refreshing Role Center page Blog bot DAX Blogs 0 03.04.2010 05:15
emeadaxsupport: Unable to edit the DCOM settings for IIS WAMREG admin service on a Windows Server 2008 R2 when trying to configure Kerberos Authentication for Role Centers Blog bot DAX Blogs 0 27.01.2010 02:08
Solutions Monkey: Kerberos configuration for Clients accessing Role Center from outside of intranet Blog bot DAX Blogs 0 21.05.2009 18:05
Solutions Monkey: KPIs in Role Center Business Overview Web Part keeps loading all the time and never ends. Blog bot DAX Blogs 0 12.03.2009 07:05
Часовой пояс GMT +3, время: 20:38.
