Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 26.03.2009, 19:55   #1
em# is offline
em#
Setting security for temporary tables without modifying the application
Hi!
Temporary tables are not shown in the security tree for assigning permissions, so it's not possible to enable them for users.
In order to make possible to set permissions to a temporary table I modified the SysDictTable class.
boolean allowSecuritySetup()
if (//this.isTmp()|| //Temporarily commented in order to show Temp tables in the Tree
this.isMap() ||
this.isView() ||
!this.securityKeyId() || //If not, the table rights cannot be calculated if the user is a member of >1 group
(this.configurationKeyId() && !isConfigurationkeyEnabled(this.configurationKeyId())))
return false;
return true;
My question is if there is a way to enable permissions for Temp tables without modifying the application.
Thank you.
kamalblogs: Setting default object owner as Object creator in Window server 2008 for AIF in Dynamics Ax Blog bot DAX Blogs 1 04.08.2010 14:24
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
gatesasbait: AP Posting fails because of security setup in Dynamics Ax 4 Blog bot DAX Blogs 0 03.02.2009 02:07
Inside Dynamics AX 4.0: Security Coding Blog bot DAX Blogs 0 31.10.2007 23:40
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 08:54.
