Старый 07.05.2014, 03:28   #1
axperf: Improving SSRS Report Performance using new R3 features - Part 6
Источник: http://blogs.msdn.com/b/axperf/archi...es-part-6.aspx
Using SrsReportDataProviderPreProcessTempDB class In Ax2012, we introduced class SrsReportDataProviderPreProcess class as the solution for long running SSRS reports that cause SSRS time out. The approach is to process data in Ax session before calling...(read more)
Старый 14.02.2017, 10:48   #2
Vadik is offline
Vadik
Модератор
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Пост похоже остался незамеченным, а там интересное:
This R3 feature is implemented in the kernel. The usage is not limited to reporting. Attached is a sample project showing how this kernel feature is used in case of multi-threading in Ax: each thread creates its own instance of a temp table, inserts rows into the table, and passes the table name back to the main thread (crossing session boundary), where contents from each temp table is then merged into one DB table using set-based insert. At the end, the code must despose the temp tables. The code is for demonstraction only. A more practical application to leverage this feature is in batch processing
-ТСЯ или -ТЬСЯ ?
Последний раз редактировалось Vadik; 14.02.2017 в 14:42.
За это сообщение автора поблагодарили: fed (3), Logger (3).
ax2012r3, srsreportdataproviderpreprocess, ssrs, thread, полезное, производительность
axperf: Improving SSRS Report Performance at Line level – Part 5 Blog bot DAX Blogs 0 26.07.2013 23:13
axperf: Improving SSRS Report Performance with Hybrid of Line-based and Set-based Processing – Part 4 Blog bot DAX Blogs 0 23.07.2013 21:12
axperf: Improving SSRS Query-based Report Performance by not Using Display Methods - Part 3 Blog bot DAX Blogs 0 23.07.2013 21:12
axperf: Improving SSRS Report Performance by Applying Filters/Ranges Earlier - Part 2 Blog bot DAX Blogs 0 20.07.2013 09:18
axperf: Improving SSRS Report Performance with Set-Based Operations - part 1 Blog bot DAX Blogs 0 20.07.2013 09:18
Часовой пояс GMT +3, время: 23:42.
