Старый 11.08.2017, 02:22   #1
organicax: Print code on sales order confirmation
Источник: https://organicax.com/2017/08/10/pri...-confirmation/
I had this question a little while back so thought I’d share as it might not be so obvious where the data comes from. If you print a sales confirmation or invoice you will see a column on the end called print code. What is this?  Well this is from a field on the tax code setup.
Here is a quick overview.
D365 July 2017 Update 8 (7.0.4565.16211)
Cheers
Lachlan
Filed under: Sales and marketing
stoneridgesoftware: Placing a Sales Order on Hold in Dynamics AX 2012: Part 2 – Holding, Tracking, Overriding & Releasing Blog bot DAX Blogs 0 27.10.2016 13:11
dynamicsaxtraining: Sales Blog bot DAX Blogs 0 25.04.2012 03:18
wiki.dynamicsbook: Changes Made in Navision Attain 3.01B Blog bot Dynamics CRM: Blogs 0 21.08.2008 20:43
Часовой пояс GMT +3, время: 23:15.
