Старый 02.12.2016, 11:11   #1
organicax: Workflow setup approval assignment – workflow owner
Источник: https://organicax.com/2016/12/01/wor...orkflow-owner/
When you are configuring workflow it’s help to understand, for approvals, the concept of the workflow owner and workflow originator. The workflow owner is the one who is assigned in the setup of the workflow as the owner. For example if you are using the hierarchy provider then that is where the workflow will start searching for a person in the hierarchy which may not be what you need in most typical workflow scenarios.
Here is a quick overview.
AX2012 CU11
Cheers
Lachlan
Filed under: Workflow
organicax: Vendor Invoice line amount for approval in workflow Blog bot DAX Blogs 0 02.12.2016 04:21
organicax: AP Invoice workflow post before or after approval Blog bot DAX Blogs 0 07.10.2016 15:11
organicax: Purchase order workflow configuration with auto approval Blog bot DAX Blogs 0 26.03.2016 04:15
atinkerersnotebook: Developing a Product Approval Workflow in Dynamics AX 2012 Blog bot DAX Blogs 0 09.11.2013 17:12
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 10:29.
