Старый 05.10.2016, 22:11   #1
organicax: Inventory adjustment journal in AX7
Источник: https://organicax.com/2016/10/05/inv...ournal-in-ax7/
If you have a need to adjust your on-hand inventory working with AX7, you can leverage a few mechanisms to do this. One of these is the adjustment journal this will let you put inventory in or take it out of the system. Considering this you might not want to let everyone have access to it to avoid unnecessary mistaken adjustments.
Here is a quick overview.
AX7 Build 7.0.4230.16130
If you are working with AX2012 you can see an overview here.
Cheers
Lachlan
Filed under: Supply chain planning
organicax: Critical on-hand inventory report AX7 Blog bot DAX Blogs 0 05.10.2016 01:14
organicax: Inventory adjustment journal with advanced warehouse tracked items. Blog bot DAX Blogs 0 19.03.2016 07:36
Часовой пояс GMT +3, время: 04:42.
