Старый 12.02.2015, 22:12   #1
palleagermark: Build a valid file name
Источник: http://www.agermark.com/2015/02/buil...file-name.html
I could find anything in AX building a true valid file name. That is only the name of the file itself, not the path.
So I came up with this:
public static Filename buildValidFilename(str _filename)
#xppTexts
#define.LeftSquareBracket('[')
#define.RightSquareBracket(']')
Filename validFilename;
str invalidFileNameChars;
new InteropPermission(InteropKind::ClrInterop).assert();
// Remove the characters that .NET defines as invalid
invalidFileNameChars = new System.String(System.IO.Path::GetInvalidFileNameChars());
validFilename = System.Text.RegularExpressions.Regex::Replace(_filename, #LeftSquareBracket + invalidFileNameChars + #RightSquareBracket, #emptyString);
// Remove the characters that .NET doesn't remove
invalidFileNameChars = @'"\\/:*?\|' + "'";
validFilename = System.Text.RegularExpressions.Regex::Replace(validFilename, #LeftSquareBracket + invalidFileNameChars + #RightSquareBracket, #emptyString);
CodeAccessPermission::revertAssert();
return validFilename;
Clean off the illegal characters from file name Blog bot DAX Blogs 0 01.05.2014 20:16
crminthefield: Creating SSL Certificates for CRM Test Environment Blog bot Dynamics CRM: Blogs 0 10.12.2013 02:12
ax-erp: Find database given physical file name Blog bot DAX Blogs 0 27.04.2012 16:11
palleagermark: Changing AOS service name Blog bot DAX Blogs 0 08.09.2011 19:11
Microsoft Dynamics CRM Team Blog: Importing two or more entities from a Single File Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
Часовой пояс GMT +3, время: 04:07.
