palleagermark: Moving labels from AX 2012 R2 to RTM via XPO's
Источник: http://www.agermark.com/2013/09/movi...r2-to-rtm.html
============== If you make an xpo export from AX 2012 R2 with labels, you'll get an error if you select "Show details" during import on AX 2012 RTM. For this to work, you need to go through the xpo file and remove lines refering to "Partition": 5637144576 Источник: http://www.agermark.com/2013/09/movi...r2-to-rtm.html
