emeadaxsupport: AX 2012 Retail POS installation issue
Источник: http://blogs.msdn.com/b/axsupport/ar...ion-issue.aspx
============== Description: AX 2012 FeaturePack Installation of AX 2012 Retail POS on POSReady 2009(Win XP) fails System Requirements ![]() Reason: AX 2012 RTM is not supporting the Windows Embedded POSReady 2009 operating system, but AX RETAIL POS supports it. Workaround: What you need to do is to execute the MSI directly with these parameters Msiexec /i directexecute=1 So for POS it would be Msiexec /i RetailPOS.msi directexecute=1 The RetailPOS.msi is found on the cd under the Msi\RetaiPOS directory Author: Kim Truelsen Blog date: 26/2-2012 Источник: http://blogs.msdn.com/b/axsupport/ar...ion-issue.aspx
