David Ferguson: Creating a report in X++ code and running
Источник: http://blogs.msdn.com/b/davidferguso...d-running.aspx
============== Here is a small job that demonstrates the main parts of build a report dynamically in X++ and launching it. X++: static void MakeReportJob(Args _args) { #AOT str reportName = 'aaMakeReport'; tableid custTableId = tablenum(CustTable); TreeNode reportNode = TreeNode::findNode(#ReportsPath); Report areport; ReportDesign design; ReportAutoDesignSpecs specs; ReportSection section; ReportRun run; ; // Delete the report if it already exists areport = reportNode.AOTfindChild(reportName); if (areport) areport.AOTdelete(); // Build the report areport = reportNode.AOTadd(reportName); areport.query().addDataSource(custTableId); design = areport.addDesign('Design'); specs = design.autoDesignSpecs(); section = specs.addSection(ReportBlockType::Body, custTableId); section.addControl(custTableId, fieldnum(CustTable, AccountNum)); section.addControl(custTableId, fieldnum(CustTable, Name)); // Now the report will not prompt for user input areport.interactive(false); areport.query().interactive(false); areport.AOTcompile(); run = ClassFactory.reportRunClass(new Args(reportName)); run.init(); run.run(); } Источник: http://blogs.msdn.com/b/davidferguso...d-running.aspx
| За это сообщение автора поблагодарили: AndyPanda (0). | |
