Старый 10.05.2017, 16:10   #1
AnGor is offline
AnGor
Аватар для AnGor
97 / 46 (2) +++
Записей в блоге: 6
? The select-query cannot find the record if it executes on the Pre-event handler. (AX 2012 R3)
Hi colleagues!
How it can be? The select-query cannot find the record if it executes on the Pre-event handler. But if it runs on the Job - it finds the record.
Here is the select
select firstOnly prDirPartyPostalAddressView where prDirPartyPostalAddressView.RecId == 5637159520;
Старый 10.05.2017, 18:38   #3
AnGor is offline
AnGor
Аватар для AnGor
97 / 46 (2) +++
Записей в блоге: 6
I have found the mistake and it was much more interesting then ValidTimeState
The method which I want to handle runs between delete() of DirPartyPostalAddressView and aosValidateDelete() of the table LogisticsPostalAddress. When I want to find the record (DirPartyPostalAddressView) it's already deleted but after negative validation the transaction was rolled back and I can find it by run the Job
dynamicsaxse: April release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 07.04.2017 20:11
axsa: MDM Adapter - Extending Dynamics AX 2012 R3 Master Data Management Blog bot DAX Blogs 0 22.05.2014 03:28
emeadaxsupport: AX Content: Deploy AX 2012 R3 on Azure Blog bot DAX Blogs 0 12.05.2014 06:17
emeadaxsupport: Get started with AX 2012 R3! Blog bot DAX Blogs 0 05.05.2014 09:11
Часовой пояс GMT +3, время: 22:30.
