Старый 22.06.2011, 21:12   #1
axaptapedia: StrRep
Источник: http://www.axaptapedia.com/StrRep
Summary: New page: ===Syntax=== str strrep(str text, int number) ===Description=== Return a string containing text repeated number times. ===Example=== strrep('ab', 3) //returns the text...
===Syntax===
===Description===
===Example===
strrep('ab', 3)
//returns the text string 'ababab'.
[[Category:String]]
Старый 22.06.2011, 21:12   #2
axaptapedia: StrLfix
Источник: http://www.axaptapedia.com/StrLfix
Summary:
===Syntax===
str strLfix(str _str, int _lenght [, char _char])
===Description===
Add character _char after string _str to obtain a string long _leng.
Default filler chararcer is ' '.
If _str is longer than _leght function return a substring of _str.
===Example===
strLfix('aaa', 5, '_')
//returns the text string 'aaa__'.
==See also==
* [[strRfix]]
* [[strRep]]
[[Category:String]]
Старый 22.06.2011, 21:12   #3
axaptapedia: StrRfix
Источник: http://www.axaptapedia.com/StrRfix
Summary: New page: ===Syntax=== str strRfix(str _str, int _lenght [, char _char]) ===Description=== Add character _char before string _str to obtain a string long _leng. Default filler chararc...
===Syntax===
===Description===
===Example===
strRfix('aaa', 5, '_')
//returns the text string '__aaa'.
==See also==
* [[strLfix]]
* [[strRep]]
[[Category:String]]
Старый 02.07.2011, 05:37   #4
axaptapedia: StrRep
Источник: http://axaptapedia.com/StrRep
===Syntax===
===Description===
===Example===
strrep('ab', 3)
[[Category:String]]
Старый 02.07.2011, 05:37   #5
Источник: http://axaptapedia.com/StrLfix
Summary:
===Syntax===
===Description===
===Example===
==See also==
* [[strRfix]]
* [[strRep]]
[[Category:String]]
Старый 02.07.2011, 05:37   #6
Источник: http://axaptapedia.com/StrRfix
===Syntax===
===Description===
===Example===
==See also==
* [[strLfix]]
* [[strRep]]
[[Category:String]]
axaptapedia: AIFEnvelopeTool Blog bot DAX Blogs 0 26.10.2009 00:08
axaptapedia: Form Control With Spell Checking Blog bot DAX Blogs 0 23.07.2009 07:05
axaptapedia: Tutorial Password Blog bot DAX Blogs 1 22.05.2009 21:23
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axaptapedia: Tutorial Form Dynalink Blog bot DAX Blogs 0 22.08.2007 23:00
Часовой пояс GMT +3, время: 04:34.
